Danozeman
posted on 10/5/08 at 09:07 AM |
Vicky green headlamp flash problem.
Iv finally got some time in the garage to try and get my car ready for sva.
Now i was doing a bit of wiring yersterday and have completely forgotten how the hell its wired up. Its been so long since iv touched it.
The problem iv got is the headlights work and flash etc when turned on however they dont flash when the lights arnt on which im assuming you need for
sva. I have a couple of other little problems occurred since it was left but this was there before.
A ny ideas on how to sort this on a Viki Green loom?
Dan
graememk
posted on 10/5/08 at 10:06 AM |
i dont think you need to be able to flash your lights for sva
flange nut
posted on 10/5/08 at 12:06 PM |
The Vicky Green wiring diagram has a few errors in it arround the column switches. Have a search and I'm sure you will find the details.
Geoff
Danozeman
posted on 10/5/08 at 04:17 PM |
I seem to remember seeing a corrected wiring diagram but cant find it.
Dan
Schrodinger
posted on 10/5/08 at 08:57 PM |
You don't need it for the SVA.
If you are using Sierra switches IIRC it just needs a link between pin 15 on each side (check this first)
Keith
Aviemore
