supercat
posted on 14/5/08 at 03:51 PM |
Very bright dashboard lights
Hi Chaps,
Can anyone recommend any bright dash (warning) lights. I have a couple of standard bulb lights at the moment but they are pretty weak when it's
sunny. Either dashboard mounted or a pod that sits on top would be good.....
James
Mr Whippy
posted on 14/5/08 at 03:55 PM |
do you drive at night?
without some dimming resistor they can be overpowering or even blinding in the dark
posted on 14/5/08 at 03:56 PM |
Superbright LED with a resistor. Jobs a good'un. Might want to put a dimmer on it so you don't blind yourself when it's dark..
russbost
posted on 14/5/08 at 04:22 PM |
If you have standard dash bulbs with the ba9 cap you can get halogen relacements that are much brighter - same wattage
Guinness
posted on 14/5/08 at 04:41 PM |
My bright 6 is pretty good.
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=L/LBRIGHT6
HTH
Mike
RazMan
posted on 14/5/08 at 04:59 PM |
The LED panel lights can look like laser beams at night so it is a good idea to have a dual brightness setting to avoid burning out your retinas at
night.
Raz
sucksqueezebangblow
posted on 15/5/08 at 08:22 AM |
With regard to ultrabright LED night brightness; rig a relay to your sidelights and connect the ultrabright LEDs through it to a standard resistor on
the (lights) off side and higher resistor to the (lights) on side (resistor to earth of course). Thus switch on side lights; LEDs dim!!
supercat
posted on 15/5/08 at 08:45 AM |
Thanks chaps. Car isn't used at night as it's a race car only so not road lgeal.....
James
