Author: Subject: can you recognise this sender?
:{THC}:YosamiteSam
posted on 16/5/08 at 08:08 PM Reply With Quote
i need to replace my fuel tank sender which is constantly leaking thro the electrical plastic in the center - its seen better cays by the looks of it - the other option is to replace the guage with a VDO one with compatible sender -
questions - can anyone recognise the sender i have? so i can replace it - its being used with a Stewart Warner guage - which aint available anymore..
second and last question - if i were to use a VDO sender how does it mount in tank? - i could use the access plate in the top of the tank to mount sender cos i cant see the old hole being the same for a new sender
GeorgeM
posted on 16/5/08 at 08:18 PM Reply With Quote
Is it a Smith's?
VDO have 5 holes iirc.
I think they come with a plate to weld to tank
Speak to John at ETB instruments - he will
know & can supply the VDO - 01702 601055
GeorgeM
Werner Van Loock
posted on 16/5/08 at 08:30 PM Reply With Quote
MG midget
http://www.clubstylus.be
philw
posted on 16/5/08 at 08:44 PM Reply With Quote
Originally posted by Werner Van Loock
MG midget
Seconded.
Macbeast
posted on 16/5/08 at 09:20 PM Reply With Quote
If it is from MG Miget, then http://www.mgocspares.co.uk/acatalog/sec_midget.html lists at about £15.00
[Edited on 16/5/08 by Macbeast]
Werner Van Loock
posted on 17/5/08 at 07:34 AM Reply With Quote
Watch out as there's 2 models, depending on buildyear of the midget. One with locking ring other with 6 holes, so ask before buying.
posted on 17/5/08 at 09:15 AM Reply With Quote
Mine van , traveller and pick up use a similar sender.
miikae
posted on 17/5/08 at 10:49 AM Reply With Quote
Check this one out as it looks the same as yours , Mini Estate/Van 1959/1983
ebay item 230245240165
Mike
[Edited on 17/5/08 by miikae]
If it can be done it i will be done .
