Ken
posted on 21/5/08 at 08:24 PM |
wrong speed on mph gauge
I have a escort mkii 4 speed gearbox with mechanical drive going to a smiths speedo out of a dolomite. Having clocked it, it would appear to be
registering only half the speed. Does anyone know if you can get a new gear drive for the gearbox or do I need a new speedo?
stevebubs
posted on 21/5/08 at 08:35 PM |
I think speedy cables may be able to recalibrate them...
posted on 21/5/08 at 08:57 PM |
Second Speedy Cables. They will need more info but if you ring them they will tell you everything you need to Know. Cost wasn't too bad last
time I had a speedo done.
bazwaz
posted on 22/5/08 at 08:22 AM |
I can recommend this guy.
http://www.jdo1.com/
Barry
posted on 22/5/08 at 09:30 AM |
If you cannot be separated from your speedo, then there are at least 2 companies that can recalibrate it for you.
this process involves changing the gears for the odometer and re-magentising the speed indicator., the latter is something that you cannot do at homw
without specaiolaist equipment.
the cost will be around £ 60.
if ou in future decide to put in a different gearbox or diff or tyre size, it may well be out.
I'd recommend you try to find a speedo from a donor that matches the above parameters - loads on aebay of a tenner.
The alternative, and I went through this dilemena, is to fit an electronic speedo.
Cost will be about 3x recalibration since you also need a sender - I made my own so it was not so ££££
this gives you total flexibility.
cheapest option is a bicycle speedo, £ 5., but needs illumination.
