LBMEFM
posted on 21/5/08 at 08:42 PM |
Plug leads
I have situated my coils one either side of the engine on the cradle on my MK Fireblade, Question is, the leads are not quite long enough, I was going
to replace them anyway, therefore where can I get cheap HT leads preferable in blue?, or are they available where you can buy the materials and make
them yourself?
Regards
Barry
[Edited on 21/5/08 by LBMEFM]
rgrs
posted on 21/5/08 at 09:33 PM |
Hi barry, the blade plug ends unscrew from the cable and the coil packs unscrew. I bought my ht cable from a local motor factors as its a standard
7mm cable. You should be able to find a blue colour or if you get frantic buy a set and cut them to size.
Regards Roger
LBMEFM
posted on 22/5/08 at 08:53 PM |
Thanks Roger. I am nearly at the stage for the first engine start up. However, I would like some advice on wiring details, would you be up for
that.
Regards
Barry
