Author: Subject: Fusible link
Macbeast
posted on 22/5/08 at 11:09 AM Reply With Quote
Fusible link
Is there anything special about a fusible link (the thing that stops your loom melting ). And where can you get one ?
mad4x4
posted on 22/5/08 at 11:19 AM Reply With Quote
it's just a big assed Fuse - rated high enough that all the leccy can run through it.
Scot's do it better in Kilts.
RazMan
posted on 22/5/08 at 11:30 AM Reply With Quote
Yep, probably something like 100A should do it - you would need a direct short to blow that one!
Raz
posted on 22/5/08 at 11:31 AM Reply With Quote
Better still fit a miniature circuit breaker ---
RazMan
posted on 22/5/08 at 11:56 AM Reply With Quote
That would be perfect, but remember to insert it into the loom - not the starter circuit which can draw over 100A when cranking.
Raz
posted on 22/5/08 at 12:04 PM Reply With Quote
I've got one of these things wired into the main loom feed wiring (NOT the starter circuit, please!)
It uses fuses like this
£2.15p for the holder, 30p per fuse, from VWP (+vat etc.)
C10CoryM
posted on 22/5/08 at 01:56 PM Reply With Quote
Fusible links are a special wire that melts at a certain amperage per inch of length. A 4" length will melt at lower amperes than a 2".
It can be identified by the soft insulation and how flexible it is.
It is a fuse, and needs to be the correct length and amperage for the circuit it is protecting. It can be replaced with any other fuse/breaker as long as it is the correct amperage.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
James
posted on 22/5/08 at 04:00 PM Reply With Quote
I got one with the BMW 7-series loom I used for extra wire colours.
Although at £2-£3 new they're hardly worth scraping your knuckles for at the breakers!
HTH,
James
Macbeast
posted on 22/5/08 at 04:32 PM Reply With Quote
Many thanks
