Author: Subject: Colour coded wiring needed?
Werner Van Loock
posted on 26/5/08 at 06:37 PM Reply With Quote
Can't find the answer on here, but does the wiring need to be colour coded for SVA? I only have red, black and white automotive wire available. And printable wire sleeves for IDing.
http://www.clubstylus.be
Guinness
posted on 26/5/08 at 06:41 PM Reply With Quote
Nope.
My cousin rebuilt his motorbike completely, including a full re-wire in black. He's colourblind so has to test everything he ever does at least twice!
Mike
DIY Si
posted on 26/5/08 at 07:34 PM Reply With Quote
Not if my car is anything to go by. It looks colour coded at one end of the tunnel, but it has a different colour coding at the other end!
Werner Van Loock
posted on 26/5/08 at 07:49 PM Reply With Quote
Thanks for the answers. so red is live, white somewhere in between and black ground
DIY Si
posted on 26/5/08 at 07:59 PM Reply With Quote
If it's any help, given the wide availability of different colours over here, when I start building an Epona, I intend to try and have a fully colour coded wiring loom. Mainly because of all the faffing about I've had to do with my car. Nothing worse than not knowing what any of the wires in a big bunch do.
posted on 26/5/08 at 08:14 PM Reply With Quote
Get some different coloured tapes and put a piece round every so often or use combinations to code them at the ends.
RazMan
posted on 27/5/08 at 05:12 AM Reply With Quote
You can get no end of colour combinations from suppliers like Premier Wiring etc. It is definitely a good idea to invest in a few metres of say 20 colours to get you started and work from there.
Raz
Pdlewis
posted on 27/5/08 at 09:26 AM Reply With Quote
If you are building a loom I'd suggest opening the yellow pages and hunting out your local harness maker I found them to be 50% cheaper than online and and bit more if you pay cash :-)
