ibakes
posted on 12/6/08 at 03:20 PM |
VDO coolant temp gauge
Hi All
I have a single wire feed to my VDO temp gauge, but have my temp sensor has 2 connections, which currently run back to the ECU. Can I run the gauge
from one of these wires? Or do I have to have another sensor?
Thanks in advance
izzywizzy
posted on 19/6/08 at 08:10 AM |
There are normally 2 coolant temperature sensors / senders.
1 is the two wire Coolant Temperature Sensor for the ECU
2 is the gauge sender - mine is single wire, i assume this is the norm.
