gy351100
posted on 15/6/08 at 09:23 PM |
fuel gauge query
hi all
I am using the Sierra fuel pump/sender unit.
The sender has resistance of 32ohms (full) to 230ohms(empty).
Does anyone know of a fuel gauge that would be compatible with this sender that is also SVA compliant.
cheers
Keith
saigonij
posted on 16/6/08 at 07:15 AM |
If you ring ETB, they can make a fuel gauge with thouse values.
miikae
posted on 16/6/08 at 09:22 AM |
Those resistance values are used on most aftermarket gauges .
Mike
If it can be done it i will be done .
