omega0684
posted on 19/6/08 at 04:43 PM |
EDIS MODULE PINS
how do you take the pins out of the edis module plug, i want to have a continuous vr sensor wire with no joins in it
Paul TigerB6
posted on 19/6/08 at 05:13 PM |
Why would you want to do that?? Surely its got to be so much easier to put a join in by soldering and heatshrinking the joints than potentially
damaging the plastic plug and then trying to find new pins. There is a little sprung tab that locks the pin in which is pushed down as the pin is
inserted and springs out to lock it in place. You need to somehow push this tab down to release the pin from the housing
ken555
posted on 19/6/08 at 05:23 PM |
How I did it
omega0684
posted on 19/6/08 at 05:54 PM |
spot on cheers fella
