LBMEFM
posted on 21/6/08 at 09:39 PM |
Rad thermo switch
On fitting may fan today I thought I should check my fan switch (Vauxhall Caviler switch on MK rad) There are only two terminals, I connected them to
check the resistance which when cold was 1 when I placed the end in boiling water for several minutes the reading did not change, I thought the switch
would close to allow current to the fan. Does this mean the switch is faulty?
mad-butcher
posted on 22/6/08 at 06:31 AM |
I use a thermometer and the continuity setting on a multi meter when the buzzer sounds the circuits complete and you can check at what temp the
circuits made
Tony
LBMEFM
posted on 22/6/08 at 06:37 AM |
That's what I did and even at boiling point the circuit did not close. So I assume that the switch is no good.
mad-butcher
posted on 22/6/08 at 07:44 AM |
Sorry missunderstood your original posting on my multi meter I can't check resistance and continuity at the same time, Personal opinion your
better off fitting a new one I also have a light on the dash so I can see when the fan is running
tony
LBMEFM
posted on 22/6/08 at 09:17 AM |
Good idea with the light Tony, thanks for that, Cheers Barry
posted on 22/6/08 at 09:21 AM |
oh yes you can!! continuity is when resistance is low, typially 1 ohm or less.
.... but back to the problem.
there are 3 tereminals - did you check resistance between the terminals and each terminal and the body?
there are some thermo switches that operate at two tempearatures.
also what is the value of resistance? if in region of 300 - 1 K ohm then that would probalby be a temperature sender .. and resistance would change
when you heat up the water.
if in doubt, replpace - they are less than a tenner anyway.
do search for X-eng and look for the thermo - switch data - this shows data for a whole range of switches (note the thread/fitting my be different to
yours)
posted on 22/6/08 at 11:15 AM |
Sounds like its knackered.....
It should go to zero ohms well before boiling....
Steve @ sVc
posted on 24/6/08 at 01:28 PM |
Warning light for cooling fan.
We have had a number of confused customers as often the fan warning light comes on when the fan is switched off.
When driving, the air causes the fan to turn - this turns the fan motor into a dynamo and reverse feeds power into the warning light. A diode solve
the problem.
Regards
Steve @ sVc
