sucksqueezebangblow
| posted on 3/7/08 at 11:06 AM |
What is "TECH" wire on 'Busa Loom
Hi All,
Does anyone know what the "TECH" wire between the ECU and Clocks on a 'Busa loom is for. I'm suspicious that it may be the wire
for the red "FI" light on the clocks but does anyone know for sure?
  Tech Wire
Clive
Paul TigerB6
| posted on 3/7/08 at 11:47 AM |
Is that not for the fault display from ECU to digital display on the clocks?
sucksqueezebangblow
| posted on 3/7/08 at 12:04 PM |
Hi Paul, what do you mean by fault display? Does something come up on the small LCD screen?
The FI light is I believe the Fuel Injection light and I think it comes on if there is a fuel injection fault which is why I'm suspicious that
the TECH wire operates this light.
Paul TigerB6
| posted on 3/7/08 at 12:39 PM |
Have a read through this - it may help.
Linky
Many bikes have the ability to read a fault code from the dash and is a big advantage to using the bike clocks in my opinion - especially with an
injected bike. As you suggest it looks like that wire might connect to the FI light but the above link may help you access the fault codes also on
your dash.
Hope this helps. (i dont have a Busa myself anyway!!)
iiyama
| posted on 3/7/08 at 03:48 PM |
FI does stand for Fuel Injection, but this light also covers many other diagnostics depending on what code is displayed in the LCD
If its broke, fix it. If it aint broke, take it apart and find out how it works!
sucksqueezebangblow
| posted on 3/7/08 at 04:03 PM |
But does the TECH wire connect to it? I'm using after market clocks so need to work out what it does.
