Author: Subject: choosing battery?
hellbent345
posted on 3/7/08 at 09:20 PM Reply With Quote
choosing battery?
i have a 2l dohc engine from ford, and i would like to know a good battery to use to start it? should i go for light and small or original spec?
thanks
omega0684
posted on 3/7/08 at 09:36 PM Reply With Quote
one that supplies 12 volts is a good place to start
indykid
posted on 3/7/08 at 09:49 PM Reply With Quote
there's cheaper places to lose weight than with your battery.
i've had a halfords calcium battery in mine for the last 3 1/2 years. it was left completely untouched for 18 months while i rebuilt it and again for 6 months over winter. each time it's started first turn of the key, strong as ever.
it's a round post one to fit a cavalier iirc. HCB063 maybe?
tom
miikae
posted on 3/7/08 at 09:53 PM Reply With Quote
I bought a 12v 48ah sealed for life jobbie for my 2ltr Pinto at a total cost of £33.98 delivered 18 months ago but i understand that due the rise in metal prices etc they are much dearer now though .
Mike
If it can be done it i will be done .
tomblyth
posted on 4/7/08 at 06:18 AM Reply With Quote
I just bought the cheapest on the shelf at halfords (micra i thint retail £ 47 ) but paid £25 with trade card! remember you will not be running loads of gadgets ( e.g elec windows ,heated seats etc)
indykid
posted on 4/7/08 at 08:33 AM Reply With Quote
but you're still cranking a 2litre engine.
the CCA of the smaller batteries can be about half the medium size ones.
tom
iank
posted on 4/7/08 at 08:34 AM Reply With Quote
This thread has some information
http://www.locostbuilders.co.uk/viewthread.php?tid=89456
Smallest non specialist battery is an A17 207x175x175 which should be fine.
As ^^^ most batteries are designed for all the toys and gewgaws in modern tintops and are much bigger than we require.
[Edited on 4/7/08 by iank]
Anonymous
iank
posted on 4/7/08 at 08:37 AM Reply With Quote
tom
But you won't be doing that in the winter so shouldn't be sawing away for 5mins trying to get a damp ignition to fire.
Anonymous
PaulBuz
posted on 5/7/08 at 01:04 PM Reply With Quote
I'm using this cheap mini battery to start my Dohc.
Engine has been rebuilt, new rings valves ground etc. LOADS of compression. It still starts ok Rescued attachment car.jpg
Paul
