001Ben
| posted on 5/7/08 at 03:12 PM |
Sender Wiring
Hi...
Can anyone I D the sender on my car? I am wiring the car but am unsure what the 2 connectrions are for , whether one is an earth or a return to the
dashboard.
The sender is:
  Sender
| posted on 5/7/08 at 04:39 PM |
Can't help with the wiring but would suggest replacing the plastic fuel pipe before it causes problems
001Ben
| posted on 5/7/08 at 04:49 PM |
will do. Its being rebuilt.
Paul TigerB6
| posted on 5/7/08 at 05:03 PM |
The plastic looking pipe is a breather and narrower diameter than the fuel outlet if that helps identify it??
Macbeast
| posted on 5/7/08 at 05:27 PM |
Generally one tag is the chassis and the other goes to the gauge. The chassis one is usually fairly obviously spot welded to the metal body of the
sender. If you can't tell from that, use a meter on a low ohms range to determine which tag goes to the body of the sender.
Edit
PS Is that a plastic tank?
[Edited on 5/7/08 by Macbeast]
001Ben
| posted on 5/7/08 at 05:50 PM |
no its a metal tank
001Ben
| posted on 6/7/08 at 12:32 PM |
Ive done as macbeast suggested and it seems to be an earth. Thanks Guys
