Slater
posted on 5/7/08 at 10:15 PM |
Earth Straps
Am I correct in thinking I need 3 earth straps? 1.8 zetec/type 9 box
- Battery -ve to chassis
- Engine block to chassis
- gearbox to chassis
Does the starter motor need one?
Can anybody recommend where to get earth straps?
Keith
Paradoxia0
posted on 5/7/08 at 10:23 PM |
I am sure someone will put me right, but I would say the battery to the chassis and the chassis to the block are a must, but as the gearbox and engine
are metal to metal this will be a good contact anyhow so not needed.
Mark
Paul TigerB6
posted on 5/7/08 at 10:31 PM |
As above, only 2 are really needed but an extra one onto the gearbox / engine assembly wont do any harm if you have the 3rd as i did in your kit. As
you dont though you may as well just stick with two. The starter is bolted to the engine so earths through that.
Macbeast
posted on 6/7/08 at 04:33 AM |
Earth straps from Halfords. I would put one from starter bolt to chassis to ensure maximum oomph, and a second one from somewhere on the block or
gearbox to chassis on belt and braces principle.
turbodisplay
posted on 6/7/08 at 08:38 AM |
Without a strap there is a good enough earth to start my car via the grounding of the diff. (wouldn`t do this as it wont do the diffs ang good) Point
is the gearbox wouldn`t need a strap.
However if the engine strap has a poor contact (corrosion), the gearbox one will start the car.
Darren
designer
posted on 6/7/08 at 09:21 AM |
Note that you should never put and earth strap to magnesium.
