Nosbod
| posted on 17/7/08 at 04:49 PM |
Rear Light Layout.
I'm planning the rear lights for my indy and am hoping to use s-v-c's "ultrabright led mix'n'match" range. The piccy
below shows my ideal and assuming I abide by the correct distances according to SVA can anyone see any problems?
My main area of concern is having the fog light with the all the others. All the cars i have seen have the fog separate and fixed near the centre of
the car.
Once again thanks in advance for any comments.
Chris.
  Rear Light Layout
Agriv8
| posted on 17/7/08 at 05:02 PM |
fog lamp has to be vertical !!!!!!
Regards
Agriv8
Paul TigerB6
| posted on 17/7/08 at 05:20 PM |
fog also has to be seperated from your side / stop lamps by a minimum of 100mm
miikae
| posted on 17/7/08 at 05:26 PM |
This may give you some ideas here of spacings etc http://westfield-world.com/svalights_rear.html
Mike
If it can be done it i will be done .
JoaoCaldeira
| posted on 18/7/08 at 07:19 AM |
You could use reflectors inside the stop lights and a separate fog in the middle.
Joao
PS: Which clusters / housings will you be using with this lights?
Nosbod
| posted on 18/7/08 at 08:04 AM |
Thanks for the advice. I'll move fog into the middle as suggested and then reflectors as below. Will they be ok now?
I'm planning to use these mounts: Linky. I know they need some work to fit but
hopefully will look good once done.
  Rear Lights Revised
JoaoCaldeira
| posted on 18/7/08 at 08:31 AM |
I think that this way they look better and more side to side balanced, though I would use either round or oval fog light (I'll probably be using
2 round fog lights in the central body, just for looks...)
This is what I've done in the past. I'd like a similar look with LEDs,
now...
That cluster will have a 3 mm problem, right?
Joao
| posted on 18/7/08 at 09:34 AM |
We'll post a picture up of our new Hella LED rears from SVC later... They are superb...
SVC are an excellent company selling excellent products - you wont be disappointed!
JoaoCaldeira
| posted on 18/7/08 at 10:43 AM |
Have you used the SVC cluster?
Waiting for those pics,
Joao
WanchaiWarrior
| posted on 20/7/08 at 10:46 PM |
Joao,
Check out Hellfire's thread here : LINKY
JoaoCaldeira
| posted on 21/7/08 at 12:43 AM |
Thanks.
Joao
