finlay
| posted on 18/7/08 at 02:11 PM |
MNR loom and rear lights
hi all
with regards my MNR rear lights and loom
i have fitted all connectors on to my loom but havent fitted the plastic connector housings yet as i wanted to test the rear lights out first by just
pushing on the clips on to each of the light terminals,
this is what the instructions show the colours on the near side as
black - earth
red black - N/S side lights x 2 wires in the same bullet
green purple - N/S stop lights
Green Red - N/S indicators
this is what the instructions show the colours on the offside as
black - earth
red white - O/S side lights x 1 wire
green purple - O/S stop lights
green white - O/S indicators
on the passenger side light cluster i have red/white going into what would be port 3 if i had fitted the plastic connector housing, earth into port 2
and green purple into port 1
and on driver side i have green purple into port 1, earth into port 2 and red/black into port 3
this combo gives me a bright stop light when i apply the brakes and a dim side light
if i swap the wires on port 3 and 1 around i get the opposite, a dim stop light and a bright side light
what combo should i use ?
also my indicators work fine both seem a strong bright signal
any feed back would be much appriciated
cheers
Finlay
richardh
| posted on 18/7/08 at 02:16 PM |
be careful here as one of my brake lights showed the earth wires on the wrong side
Brake light feed is in centre of the 3 prong connectors
easy to check with a big stick to hold pedal down etc or get a mate
richardh
| posted on 18/7/08 at 02:17 PM |
if really stuck i can photo mine tonight for you.
if you need then just u2u me later
richardh
| posted on 18/7/08 at 07:16 PM |
Hi
pic is of nearside
offside i had to bodge a bit until i found the problem.
but in short, the green purple is in middle block, 2 red/black in same connector to one side
black on other
also my nearside is 2 core one which goes to the 3rd high level one
offside
i have black on one side
single dual colour in middle and others on other end
the best way to sort it is to get a mate to keep power to ignition so brake circuit will work and then bare the ends of the brake feed wire and earth
only and put the brake on the centre terminal and the earth to both ends to see which gives brightest light
then touch the side wire to remaining side and turn the lights on
youll need to do the same for other side otherwise you'll get caught out like i did
take wheels off for ease or remove the bulb block bit
if your really up to it then an ammeter will do same job but i did it manually in the end.
finlay
| posted on 19/7/08 at 06:15 AM |
excellent
cheers Richard
