posted on 19/7/08 at 09:57 AM |
SVC range of Hella mix n match LED's
We've recently replaced our rear inner lamps with SVC's range of Hella mix n match LED's. They were a straight replacement for our
previous indicators and brake light. Very easy to fit and being LED, there is no bulky connectors intruding into the rear wheel space.
Another superb product and extremely efficient service from SVC.
Pics;
  Mix n Match LED's 1
  Mix n Match LED's 2
The bottom picture really doesn't do them the justice they deserve. The light output is superb. I'll get another picture of them in the dark
to give some idea.........
Phil
Nosbod
| posted on 19/7/08 at 11:10 AM |
Very nice, exactly the same as i'm planning to do.
eddbaz
| posted on 19/7/08 at 06:32 PM |
Hi phil,
I've brought the same light unit,a combined stop and tail light with an indicator outer ring, I am right in thinking that this is all I need and
only need to fit one unit per side,I'm a bit worried now seeing that you have two on each side,canm you tell me what the lights are on
yours,cheers
Ed
(i said the silly questions would keep coming)
| posted on 19/7/08 at 08:44 PM |
If we take the nearside, as pictured...
Both rings are tail lights.
Outer centre is tail/stop light combination.
Inner centre is indicator.
Yours should be fine - at the time we bought ours, they didn't have a ring indicator. So we couldn't use that combination.
[Edited on 19-7-08 by Hellfire]
Nosbod
| posted on 21/7/08 at 10:01 AM |
quote: Originally posted by eddbaz
Hi phil,
yours,cheers
Ed
Ed,
I was going to use this combo initially but if you need an SVA test it wont pass using the LED as tail and stop - they need to be separate lights. (I
was told this first hand by a tester at Beverley).
Chris.
| posted on 21/7/08 at 07:46 PM |
Picture taken at dusk
Phil
  Rear Dark
Steve @ sVc
| posted on 22/7/08 at 03:22 PM |
Hi Nosbod
Combined stop/tail lights & SVA.
Can’t understand this as a huge number of kit cars pass the SVA with combined stop/tail lights. The LED lights seen here have been “E” marked as
stop/tail and so, if fitted in the correct position on your car, an SVA tester should not have any problems passing it.
However if you do have a fail because of this, with lights purchased from sVc, PLEASE let me know.
As members of full members of Status (Specialist Transport Advisory & Testing Utility Society) we have direct contact with SVA HQ.
We would need the name of the testing station, the date of test and the tester’s name.
Best wishes
Steve @ sVc
ps
Phil & Steve
Those lights look superb on your car !!!
adithorp
| posted on 22/7/08 at 09:15 PM |
I passed SVA at the end of May with LED lights. They're the larger Hella units and the outer ring is stop/tail.
http://i189.photobucket.com/albums/z282/adrianthorp/Pre-SVA002.jpg
adrian
RK
| posted on 4/9/08 at 10:49 PM |
Adrian, where did you find those? They look great.
Vindi_andy
| posted on 5/9/08 at 11:07 AM |
got same arrangement i.e. stop/tail outer indicator inner also reflector outer with fog one side reverse the other
Don't need the reverse but do need fog for SVA so used reverse for balance
