mikeb
| posted on 21/7/08 at 11:59 AM |
Gauges
Even though I don't need them yet I'm on the look out for a cheap set of gauges.
Found this on ebay.
Think it's from a porshe, could be a cheap bright 6 plus temp and fuel,
Your thoughts or any other option for cheap gauges (seperates rather than donor style)?
what type of speedo and rev counter do I need if running carbs on a megajolt.
If I go for a non ford speedo what are the options for speedo cable etc?
[Edited on 21/7/08 by mikeb]
| posted on 21/7/08 at 12:09 PM |
I've used an Acewell on mine, has everything apart in the unit. The only other thing I have on the dash ATM is a fog light switch.
nib1980
| posted on 21/7/08 at 12:13 PM |
go electronic and use sensors.
if you stay analogue, and use cables, speeycables will make most things up you need.
oh and i intened to take my car to work at some point this week so may pop in on the way home and say hello if your about
mikeb
| posted on 21/7/08 at 12:22 PM |
Just been looking at a set of gauges from a 924, sure I could get them for peanuts.
If I got electronic.
I assume the megajolt can do the whats required for the rev, how do you sort out the speedo, is there an electronic sender for the type 9 or do you
put a sensor on the prop?
Will be around everynight except friday.
send me a txt on your way over as I might be walking the dog!
M
whitestu
| posted on 21/7/08 at 12:26 PM |
I'll second the Acewell - I'm very pleased with mine.
The speedo sensor is basically the same as on a pushbike. i.e. a magnet and a sensor.
Mine is on the prop.
With the Acewell you also get temp, fuel, volts, trip and all the warning lights you'll need.
You probably won't get a useable tacho signal out of the MJ. Better to take a feed of the coil pack.
Stu
[Edited on 21/7/08 by whitestu]
Paul (Notts)
| posted on 21/7/08 at 02:14 PM |
If you do go for the one in the picture then I have a wiring diagram for it and know a place that does the connector for the pins on the back. However
it’s a little complicated to wire up.
I have used this display as I got one for £10 and wanted an old fashion look.
P.s. you will need to remove the current pyramid plastic display cover and cut a flat Perspex one for it. Not to hard.( but extra cost )
Paul
