Author: Subject: Earth Point
Dave Bailey
posted on 25/7/08 at 10:57 PM Reply With Quote
Earth Point
Anyone drilled a hole through the firewall in the pasenger footwell and bolted studs in to get an earth point? I don't want to weld my chassis with Studs.... having had it painted.... I know should have welded the studs in before...too late now!
Dave B
mangogrooveworkshop
posted on 25/7/08 at 11:00 PM Reply With Quote
drill and tap....stainless bolt is best
omega 24 v6
posted on 26/7/08 at 07:50 AM Reply With Quote
Yes me. 8mmbolt (head in pass footwell) spring washer and plai nut done up tight and the the terminals onto the remaing bolt and a washer/locknut to secure. Then a spray of white grease for protection.
posted on 26/7/08 at 10:15 AM Reply With Quote
Personally I just drilled a hole in the chassis and used a coach screw to clamp the earth strap onto the chassis. The coach screw is in contact with the thread it produces so you get a good contact....
No problems yet....
001Ben
posted on 26/7/08 at 10:42 AM Reply With Quote
why not use rivnut bits
posted on 26/7/08 at 03:01 PM Reply With Quote
Yep, my battery is down the side of the passenger footwell and the earth point is a short load bolted to the bulkhead. The same lead goes through to the engine bay and is bolted to the engine block as well.
tomblyth
posted on 26/7/08 at 06:06 PM Reply With Quote
see my photo's the battery is in the footwell! conections through the front!
