big_wasa
posted on 3/8/08 at 06:46 PM |
Lots Fs - some free some not.
Cash and space injection needed so its clear out time
T9 gear box.....
With 1.8 zetec fly wheel + New valeo clutch kit to suite + new capri long thrust bearing + new zetec spigot bearing + used but good Dohc starter motor
+ Tin cover that goes in between engine and box (needs bit adding to suite zetec)
So thats all the corect bits to make a zetec rwd in one place...........£130
2.0 Zetec Apr 1994 Silver top I bought the car to get this engine as a spare. It had done 98k miles.
It comes with 1.8l escort fly wheel + 1.8l water pump and pulley not yet fitted + new head gasket set and bolts new cambelt all not yed fitted. I also
have a new set of rings, (1 oil control ring is used).
So thats a pre Aug 95 engine for getting through sva with the bits to freshen up.................................£220
[edit to remove bits ive binned or sold
[Edited on 2/10/08 by big_wasa]
Benzine
posted on 3/8/08 at 07:02 PM |
U2U sent
scotty g
Thats a hell of a clear out you're having there wasa!
whitestu
posted on 3/8/08 at 07:54 PM |
If you were closer I'd have the blacktop 2.0 off you!
stu
dave1888
posted on 3/8/08 at 08:19 PM |
Standard ford injection system.
Thats a 2.0l pre pats ecu + cut down wiring loom + Maf + 2 throtle bodies (one modified to fit an escort manifold + Air temp sensor + 2 sets of
injectors with fuel rail ( side fed and end fed).+ Mondeo manifold + Ford injection Book.
Basicly this will run a standard 2.0l engine in a kitcar or say a 2.0l Fiesta conversion. No Pats. just a case of conecting the lives and earths and a
couple of relays for fuel pump and fan needs Lambada sensor in exhaust to run closed loop ............... £75
Tell me more im interested. Is it the plastic manifold type
big_wasa
posted on 3/8/08 at 08:28 PM |
yep plastic manifold but its for a 2.0l I think you said yours is 1.8. It would probaly over fuel it.
auzziejim
posted on 4/8/08 at 05:57 PM |
hi warren does the panhard rod have any bushes and brackets?
cheers
james
big_wasa
posted on 4/8/08 at 08:10 PM |
James you dont want much do ya
Nope it needs the bush one end and a m12 rose joint on the other.
auzziejim
posted on 4/8/08 at 08:40 PM |
thats fine mate, i'l take is please
can i pop over one night later on in the week?
cheers
james
RMarine
posted on 4/10/08 at 07:49 PM |
Cheers for the link... this sounds like what i need. is there a discount if i buy both The engine and gearbox![](/images//smilies/wink.gif) ![](/images//smilies/bigsmile.gif)
dazgsxr
posted on 18/11/08 at 09:47 PM |
Hi mate is the gearbox still up for sale?? where are you ??
daz161272@yahoo.co.uk
Life shud be measured in the amount of times your breath is taken away not by the amount of breaths you take!!!
