Author: Subject: VDO Gauge Connctions
Dick Axtell
posted on 5/8/08 at 08:11 AM Reply With Quote
To anyone who's fitted VDO clocks :-
According to the VDO data sheet, the rear connections are i) ign switch live to "B", ii) sensor feed to "T", and iii) earth, as marked.
However, my VDO gauges have the following markings on the back :-
i) "G", ii) "+", and iii) what looks like an inverted "T".
AFAIR, the last one, (iii), is another version of earth (or "ground", in some foreign parts).
So, can anyone advise me what connects to "G" and "+"?
Thanks for any feedback.
nib1980
posted on 5/8/08 at 08:50 AM Reply With Quote
AFAIK
G= ground
+= Positive
T or S = Signal
hope that helps
posted on 5/8/08 at 08:54 AM Reply With Quote
... except it is not a T but an inverted T like symbol.
I recommend you contact VDO or someone who supplies VDO guages.
Can you post photo? Usually the ground will be connected to the case.
Dick Axtell
posted on 5/8/08 at 08:57 AM Reply With Quote
Thanks for the interesting feedback. I'll try to post a pic later today.
nib1980
posted on 5/8/08 at 09:03 AM Reply With Quote
try here, it's what I used
http://www.greengauges.com/help/faq11.asp
Dusty
posted on 5/8/08 at 10:24 AM Reply With Quote
G(S) is sensor, + is switched live and the upside down T with the fat crossbar is ground as you had worked out. My small gauges have the blades on the back arranged in a U shape. Looking at the rear of the gauge 12v feed on the left upright, ground across the bottom and sensor on right upright.
(Marked on my oil pressure sensor as G(S) to gauge, WK to oil warning light)
[Edited on 5/8/08 by Dusty]
BillHoll
posted on 5/8/08 at 11:18 AM Reply With Quote
This should help.
BillHoll
posted on 5/8/08 at 11:27 AM Reply With Quote
Sorry the attachment link does not appear to be working. If you U2U me with your email I will send you the VDO wiring diagrams. and now it does???
[Edited on 5/8/08 by BillHoll]
Dick Axtell
posted on 5/8/08 at 02:22 PM Reply With Quote
Dusty and BillHoll,
Many thanks for your advice.
Dusty - my gauges have exactly the same layout and markings as you described. Will re-check my dash panel wiring, just to be sure.
