FASTdan
| posted on 6/8/08 at 07:00 AM |
pinto ignition wiring
I am currently finishing someone elses MK build with a 2.0 pinto (E reg injection donour sierra). The loom is in (premier I believe) but so far the
only thing that appears connected is the ignition barrel. My first aim is simply to get the ignition and starter circuits working so I can get the car
movable.
I have been provided with a transit dizzy and ignition module - the guy told me these are what is required to run this engine in a basic form (as
previously it would have been engine management). Are there any wiring diagrams for these bits available? What coil is suitable? You will have to
forgive my ignorance, im very new to this!
Guidance would be very appreciated! I had a search on the subject but to no avail (maybe im not using the search function correctly.
| posted on 6/8/08 at 08:17 AM |
Is it still in EFI form or has it been changed to carb(s)?
Does this help?
  Ford IGN wiring
FASTdan
| posted on 6/8/08 at 10:30 AM |
yes, sorry should have mentioned that. Its got twin dellorto's on it - all the old management binned.
That diagram looks like it might be useful thanks. Does the transit dizzy + module (or amplifier as shown on diagram) sound right?
| posted on 6/8/08 at 10:44 AM |
Not sure if there's any difference between Transit and Sierra dizzy and amp, but the part number on my Sierra sourced amp is...
Motorcraft
83BB 12A199 B3A
095078
bob
| posted on 6/8/08 at 12:11 PM |
Transit electronic dizzy should be fine, same as i used on my pinto set up. Its a cheap entry level into pointless ign.
Here is diag as my wiring was, didnt use the white wire, probs the same as nicks.Image deleted by owner
bob
Amp as this
FASTdan
| posted on 6/8/08 at 12:54 PM |
Hi Bob,
that looks like the one I have, good to hear I'm on the right track then. I may upgrade in the future but this seems like a good place to start
to get the car running.
thanks for the info guys, I'll post back when I get stuck lol.
