Pdlewis
posted on 10/8/08 at 10:13 AM |
Bettery Cable ends
Im still doing my electrics and have come to the battery connections. I have the cable but im not sure about what ends (rings) should i use or does
anywhere know anywhere i could send cables to get some ends put on properly?
Paul
Build Photo Album
Updated 05/02/2009
posted on 10/8/08 at 10:22 AM |
http://www.vehicle-wiring-products.eu/VWP-onlinestore/battconns/battleads.php
is it worth it??
I'd be tempted to just buy a battery cables of the right size...
Otherwise I'm pretty sure VWP would do it but you'ld obviously have to pay postage to get it there and at those prices.....
Shamrock GS
posted on 10/8/08 at 11:01 AM |
'Vehicle Wiring Products' do all the connectors and cables in different sizes. Just buy what you need and solder the joints yourself. V
easy and made to measure.
Gary
Sun Tzu, The Art of War
Shamrock GS
posted on 10/8/08 at 11:06 AM |
See the 'For Sale' thread that's just opened
G
worX
posted on 10/8/08 at 12:37 PM |
I'll crimp on proper battery terminals for you, no problem!
Just send me a U2U if you want me too.
(no charge)
posted on 10/8/08 at 02:57 PM |
Crimp & then solder using a blow lamp
posted on 11/8/08 at 10:42 AM |
although I had to solder on a battery connector once in the past - can't remember why - I would not recommend it.
You want the best possible electical connection and crimping is the way.
If you don't have the tool, you can make one. I keep meaning to post a photo but will attempt to describe it.
A block of steel with a V groove cut in it.
A small metal rod, say 4 mm diameter - could be a bolt cut to length.
Put the connector into the V and the rod o nthe other side, all in a vice.
Do up the vice.
The rod will push the connector nice and tight without squashing or defrming the conenctor - it rmains cirular but a bit pushed in indent - hard for
me to explain ....
I have used this method and not had any problems, no solder required.
