Author: Subject: hella lights
Stuart_B
posted on 20/8/08 at 03:10 PM Reply With Quote
hella lights
hi all, i have got a set of hella led rear lights with led's outer ring, do i need to wire up any restiors or are they built in? as well do i need to change my flasher Relay? if i do does that mean i need led side indactors and led front indactors? or will normal side and front indactors be ok?
thanks
stuart
posted on 20/8/08 at 04:20 PM Reply With Quote
Brake Lights, tail lights etc dont need any further suppression as it is built in.
You can mix LED's with standard bulb's but be careful of the relay maximum wattage. It must handle all 6 bulbs (for the Hazards). Front, Side and Rear - (21W + 5W +21W) * 2 for both sides = 94W.
We have rear LED indicators using the original relay. Took the 5W bulb out of the side and replaced it with the rear 21W bulb. The LED indicator takes 2W. This all combined makes very little difference to the flash rate.
[Edited on 20-8-08 by Hellfire]
