Author: Subject: More SVA dash questions!
meggsy
posted on 21/8/08 at 05:23 PM Reply With Quote
Now sorting the dash - What are the SVA requirements for the following??
Horn Switch - Position / Type
Rear Fog light switch - Position / Type
Position of speedo (thinking center of dash?)
Other switches - Fuel Prime / Fan Etc
Any advice appreciated
Rich
Paul TigerB6
posted on 21/8/08 at 05:53 PM Reply With Quote
Just need to ensure switches have no sharp edges really unless they sit within the exempt area. You dont need a horn for SVA so no need to worry about that except for radius edges if fitted.
Fog light switch - well you need a telltale to show when its working (ie seperate warning light or wire in the backlight to operate when the foglight is on)
Speedo - well i think they just require an uninterupted view of this - should be easy if fitting behind the wheel by using a standard Sierra wheel.
LBMEFM
posted on 21/8/08 at 08:35 PM Reply With Quote
Don't forget the handbrake/low fluid level warning light.
Barry
posted on 22/8/08 at 07:22 AM Reply With Quote
.... but you'll need horn for MOT so best to fit it when everying is in bits rather than later.
another switch would be battery isolation switch = 1 means of immobilistation.
richardh
posted on 22/8/08 at 07:24 AM Reply With Quote
savage switches are really good but can be tricky to wire (really good and flat for sva man)
