Philippe
posted on 1/9/08 at 02:30 PM |
Lexan windshield??
Does anyone use a polycarbonate windshield? I understand that the weight saving can be 50% and that we can bend our own with some heat. What are the
pluses and minuses. In the UK do polycarbonate windshields and windows qualify for SVA?
Thanks.
PHilippe
andyps
posted on 1/9/08 at 02:50 PM |
As far as I know a polycarbonate windscreen would not be allowed in the UK. The simple problem with one would be that it would almost certainly become
opaque pretty quickly once you started using wipers on it as they scratch pretty easily. I find not being able to see is a pretty big minus most of
the time whilst driving - although passengers may appreciate it
Edited to add - generally OK for windows other than the front screen.
[Edited on 1/9/08 by andyps]
hellbent345
posted on 1/9/08 at 02:57 PM |
i dont think pc windscreens are sva legal, sidescreens are fine i think but you want to be careful even adding it after sva because it scratches very
easily unless its given a hardcoat, and home bending will be quite hard as if you dont heat it up enough it will form stress cracks that look like a
haze very easily, and will distort if you heat it to much, also if you dont want marks in it you have to be uber careful what you bend it with (ie
hard tools - that means anything harder than soft pc)
al
Humbug
posted on 1/9/08 at 03:57 PM |
OK as long as it is used as a flyscreen i.e. half height
contaminated
posted on 1/9/08 at 04:43 PM |
I made an aero screen from Lexan which is fine. Forget it for a full screen though - the wipers will scratch it to bits.
Canada EH!
posted on 1/9/08 at 04:45 PM |
Lexan windshield
There is a hardened surface Lexan used to protect school windows, but wipers would eventually wear off the coating. You can not wear Polorized sun
glasses as the Lexan gives the impression of looking through oil spilled on water. I found out when I repalced the side windows on my 2 place
airplane. The other problem, large shunt and you get to the windshield, it isn't going to break, have your helmet on.
Philippe
posted on 1/9/08 at 07:54 PM |
Pc windshield
Thanks guys,
Yes lexan does not look too promising here in Canada either. I will keep looking and if I find anything spectacular I will keep you posted.
Philippe
DarrenW
posted on 2/9/08 at 11:55 AM |
Im sure it was Lexan that we used for machine guards a while back. Whilst very tough for impacts it did scratch easily. Didnt use rubber wipers on it
though. Whilst i would doubt the rubber would scratch it the road dirt almost certainly would.
I seem to recall SVA book saying windscreens had to have the relevant safety mark on them.
For SVA i passed with no screen, might be an option.
