Author: Subject: pinto dizzy black thing ?
zzr1100rick2
posted on 6/9/08 at 03:28 PM Reply With Quote
Hi i have a pinto dizzy with a black thing inline with the wire that goes to the points its about the size of a postage stamp What is it ? cheers for any answers Rick
mookaloid
posted on 6/9/08 at 03:52 PM Reply With Quote
if it isn't the condensor then it could be some sort of radio intertfetrence suppressor
russbost
posted on 6/9/08 at 03:59 PM Reply With Quote
Yep, radio supressor, you can disconnect it, throw it away & save the weight!!!
posted on 6/9/08 at 04:31 PM Reply With Quote
Will also cut down on voltage loss in the low tension curcuit by losing it . Would suggest fitting a small earth lead between the distributor base plate and one of the points securing screws which helps with cold starting etc
zzr1100rick2
posted on 6/9/08 at 05:40 PM Reply With Quote
cheers people will be cut out and binned when i get to work on monday
