blakep82
posted on 13/9/08 at 08:51 AM |
can these be used for reverse light & side lights?
http://www.cbsonline.co.uk/all-purpose-white-led-strip-lamp-apled-3446-p.asp
quite like the minimalist look, but don't seem to be e marked. they do have e marked ones for £22 a pair, but i don't like the
housing's they're in
________________________
posted on 13/9/08 at 09:18 AM |
I doubt Mr SVA man would like it.... I'd fit some bog standard ones in such a way that you can fit those afterwards....
matt_claydon
posted on 13/9/08 at 09:23 AM |
Lights do not have to be e-marked so I don't see a problem. Reverse lights are not even a tested item so definitely no problem there.
posted on 13/9/08 at 09:40 AM |
Lights don't *have* to be e-marked but if they are not e-marked they have to be deemed "equivalent" by the tester. In my experience
they dislike anything that isn't E-marked (cos they failed my fog light which was brighter than the E-marked one I replaced it with and they
were happy with).....
blakep82
posted on 13/9/08 at 09:45 AM |
both very good points.
replace after it is then. except the reverse light maybe. perhaps i'll just not have one to start with.
cheers guys!
matt_claydon
posted on 13/9/08 at 09:47 AM |
With a non e-marked fog lamp the tester has to make a judgement as to whether it has a brightness of at least 150 candelas (not easy, so he's
probably going to err on the side of caution).
With side lamps brightness is not an issue so I wouldn't have thought they would have any reason for complaint (unless they are excessively
bright and liable to dazzle).
