Author: Subject: Quick Shift for ford
maskell01
posted on 16/9/08 at 09:14 PM Reply With Quote
I found this site just yesterday,it gate detailed instuctions on how to convert the standard gearbox to a quickshift,but its not working now!any idea's how to do this?
Quickshift Link
Danozeman
posted on 16/9/08 at 09:27 PM Reply With Quote
What about this one from David Jenkins.
extension and quickshift.
Dan
blakep82
posted on 16/9/08 at 11:06 PM Reply With Quote
Quickshift Link
your link works now
________________________
Paul TigerB6
posted on 17/9/08 at 12:25 AM Reply With Quote
The link simply moves the pivot point and so shortens the throw of the type 9 gearstick. You can easily do this yourself for little or no cost - hammer plus a few washers!!
clairetoo
posted on 17/9/08 at 06:04 AM Reply With Quote
I fitted a quick-shift to my Fury a long time ago but I found it allmost impossible to find the gear I wanted - I found myself trying to pull away in anything other than first so off it came
I've still got the nylon spacer for the gear lever if any one want's it ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
tcr
posted on 19/9/08 at 06:11 PM Reply With Quote
i had the same problem on the ford 4 speed you didnt know if you were in 1st 3rd or reverse so i took it out to
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
posted on 19/9/08 at 06:17 PM Reply With Quote
I used Dave Andrew's method as part of my remote mechanism.
I found that it works very well, as long as you don't shorten the gearstick too much. The temptation is to make the stick short and stubby, but you will have already reduced the lever ratio so it can be hard to move.
I would recommend that you find an old Type-9 gearstick in a scrappy and play with that - you can then revert to the old one if it doesn't suit you (but they are getting scarce and harder to find, but the looks of those 'Wanted' ads that keep appearing).
