tegwin
posted on 19/9/08 at 08:55 PM |
Cr@p...I just snapped my nipple..
Trying to undo the bleed nipple on my rear slave cylinder (Drum type) and the darn thing sheared off....
Is there any possible way of getting the remainder out, or am I looking at a new slave?.....the nipple must be wedged in there proper hard to snap a
nipple!
www.verticalhorizonsmedia.tv
Howlor
posted on 19/9/08 at 08:57 PM |
If you don't mind a new seal kit then try plenty of heat and a removal set.
There again a new cylinder is probably cheaper than a seal kit!
nitram38
posted on 19/9/08 at 09:04 PM |
If it is steel, mig weld a blob on top and weld a small bar/steel strip to the blob.
The heat from the weld should help shift it when you turn the bar.
Danozeman
posted on 19/9/08 at 09:05 PM |
easy out?
Dan
jollygreengiant
posted on 19/9/08 at 09:13 PM |
Look at it this way, 2 minutes to Change a cylinder at a cost of about a tenner, OR, about an hour of faffing around trying/succeding in getting the
nipple out and then you have to find a nipple and bleed the system/wheel anyway.
With changing the cylinder, at least you know its new and will have peace of mind.
For me its a no brainer, ............ New cylinder.
nitram38
quote: Originally posted by Danozeman
easy out?
Never use these!
They snap easily and then you will need a spark eroder to remove the mess!
You can't drill a snapped "easy out"
jambojeef
posted on 19/9/08 at 09:20 PM |
They are an utter doddle to get out with a stud extractor.
Hole already the right size just wind it out...
What could possibly go wrong?!
tegwin
posted on 19/9/08 at 09:32 PM |
A new slave Cyl is about £20....its a Triumph TR6 rear IRS....
Will have to take the entire thing to pieces tommorow and see whats what
tomgregory2000
posted on 19/9/08 at 09:34 PM |
new slave
its brakes not some where i would try and save a bit of cash its some where i would spend the cash, much better than a brick wall or a tree
posted on 19/9/08 at 10:59 PM |
Having always read the "mig a nut on" and thought "that'd never work" I was mightily bemused when I tried it the other
day and it worked like blooming clockwork....
ashg
posted on 20/9/08 at 12:01 AM |
mig and nut gets my vote.
hold an m8 over the nipple then blast through the centre of the nut with the mig.
wait to cool then turn with spanner. job done.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
zetec7
posted on 20/9/08 at 04:57 AM |
There are TWO kinds of easy-outs...the ones that look like left-hand thread screws (DON'T use these! They're hard as files, and break
very easily), and the type that are square in cross-section, kind of like a piece of square stock steel that tapers slightly. These ones are spring
tempered, and VERY hard to break. You just tap it into the hole in the nipple, and unscrew it. One size of this type fits several hole sizes, so 3-4
of these will cover most of the things you'll have to remove...
http://www.freewebs.com/zetec7/
posted on 20/9/08 at 09:22 AM |
Just bleed it by slackening the pipe union -- single pump close the nipple while a helper holds down the pedal, bring the pedal up and repeat say 3
times.
NB I have noticed an increasing trend on the web to call wheel cylinders "slave" cylinders --- this causes confusion slave
cylnders are for clutches.
[Edited on 20/9/08 by britishtrident]
indykid
posted on 20/9/08 at 09:41 AM |
[/pedant hat on] a wheel cylinder is a slave cylinder.......
a slave cylinder isn't necessarily a wheel cylinder. [pedant hat on]
tom
posted on 20/9/08 at 11:58 AM |
tom
No it is an motor industry convention used in brake manufacturers parts catalogues for the 80 years or so cars have been fitted with hydraulic
brakes. If you use the wrong terms don't blame the supplier when they supply the wrong parts.
Slave cylinder -- clutch
wheel cylinder --- wheel back plate mounted brake cylinder
frame cylinder -- axle mounted brake cylinder (as on old cars like the Austin A30)
posted on 20/9/08 at 05:13 PM |
As BT states slave cylinder is for clutch and wheel cylinder is for brakes . Ask anybody that works in the motor trade.
posted on 20/9/08 at 08:32 PM |
apparently these ones work well:
from this:
to this:
[Edited on 20/9/08 by 02GF74]
