Author: Subject: STM/Aries Locoblade loom...???
Richard Quinn
posted on 22/9/08 at 03:32 PM Reply With Quote
Is anyone using the STM/Aries Locoblade loom as supplied by Aries? If so, do you know how the fan is wired? I have only got as far as laying the loom out in the car and there are two terminals at the front of the loom for the fan. There is wiring for a fan switch on the dash. The loom is designed for parts of an 893 'blade loom to be spliced in but, as far as I am aware, there is no ecu fan control on the 893 'blade.
Does the fan only come on with the dash switch?
Before anyone says anything too smart, the only drawing you get is a layout rather than a wiring diagram so I know that I have a red/black and a purple wire at the switch and a red/black and two blacks at the fan!
ReMan
posted on 22/9/08 at 05:29 PM Reply With Quote
The bike has a thermoswitch in the rad which kicks th fan in at some temperture or other!
The rad you have should also have one, if you are lucky it will work, then as a back up, you have the switch
Paul TigerB6
posted on 22/9/08 at 06:56 PM Reply With Quote
You ought to just find some complete mug to come and wire the car up for you / with you!!
Richard Quinn
posted on 22/9/08 at 07:03 PM Reply With Quote
I know! But it would be useful if we had a fighting chance. You haven't seen the multi-coloured bird's nest I've got left from what was the bike loom that I've got in store for you!
Paul TigerB6
posted on 22/9/08 at 07:07 PM Reply With Quote
Oh joy!!! With Ben's car we got the lighting side of the loom sorted out before then splicing in the bike loom to run the engine. The R1 uses a thermo unit to run the rad fan and temp guage via the bike loom so hopefully yours will be similar!!
Do you have a wiring diagram to view online anywhere??
posted on 22/9/08 at 09:09 PM Reply With Quote
I've got the hand-drawn wiring diagram that came with my (blade) loom when I got mine from STM. u2u me if you want a copy!!!! It shows 2* black and 1* black/red for the fan... I ran my black/red via the radiator switch then the output of that to the fan...
Richard Quinn
posted on 22/9/08 at 09:37 PM Reply With Quote
Ben - Is it a wiring diagram or just the layout schematic? Does the dash switch then have to be on for the thermo switch to operate?
