vinnievector
| posted on 23/9/08 at 04:21 PM |
ignition
Hi need a feed to my coil via fuse from the ign barrel late ford sierra . any ideas wot coulour and how you guys have gone about wiring up the supply
Dusty
| posted on 23/9/08 at 04:33 PM |
You need to feed quite a lot of stuff with either switched live fused supply or constant live fused supply. I used the ignition barrel to switch a
40amp relay to supply several fuses in the fuse box. Several other fuses were wired direct to the battery positive. This then gives your sources of
fused switched or constant live current.
