chrisspartan
posted on 26/9/08 at 11:35 PM |
Brake Balance (Bias) Valve
I have just noticed that 'scotty' has just failed SVA for brake balance.
I havent got a balance valve on my Indy with drums on the rear, am I going to have problems with SVA?
Has everyone else got a brake bias valve fitted??
Chris
zetec7
posted on 27/9/08 at 04:14 AM |
I haven't done my brakes yet, but I, too, have disc/drum brakes. I bought a Wilwood hydraulic balance adjuster (Wilwood part No. 260-2220).
Nice unit, simple to install, if not quite reasonably priced
http://www.freewebs.com/zetec7/
posted on 27/9/08 at 08:08 AM |
scotty failed because his bias bar was set too far towards the rear.
If you really want a pressure regulator go for the Fiat/Lada ones of a Strata/Ritmo Uno or Lada Riva -- about 15 pounds from brakes
international --- you need to make a simple bracket up for an adjusting screw to push down the plunger, the more theplunger is pushed in the higher
the pressure to the rear brakes
[Edited on 27/9/08 by britishtrident]
