Author: Subject: HALP! Horsebox electrics
Benzine
posted on 2/10/08 at 10:33 AM Reply With Quote
I'm doing a favour for a friend who runs a stable. She's got a Leyland Daf 45 150 Turbo. The indicators were being very unpredictable so I offered to have a look. The hazards work fine, fuses and relays are fine. Then I looked at the actual indicator lever on the steering column. It has loads of play in it, it's pretty obvious that that is the problem
Anyway, I took it apart and loads of tiny springs, ball bearings, little bits of plastic fly everywhere (some are lost, and when I say lost i mean they flew out the door into thick grass never to be found again)
So does anyone know where I can get parts for such a vehicle (these small indicator switch components) and maybe a diagram of how they go together?
Spanks
The horsebox is like this one:
http://cgi.ebay.co.uk/Leyland-DAF-45-150-Turbo-Horsebox_W0QQitemZ150300013601QQcmdZViewItem ?hash=item150300013601&_trkparms=72%3A1350%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
blakep82
posted on 2/10/08 at 10:40 AM Reply With Quote
try this number
0141 429 3141
stanley r harris are an HGV/PSV parts suppliers in glasgow (i'm sure they must do delivery if needed) I'm not a HGV driver, but i went in to ask about LED rear lights, and they were very helpful.
I don't know if they'll be able to do you the bits to repair that one, but i'm sure they could do you a new stalk if you're really stuck?
________________________
Mr Whippy
posted on 2/10/08 at 10:48 AM Reply With Quote
Superb, this is why not to volunteer to fix things, wait till you try to put it back together!
matt_claydon
posted on 2/10/08 at 11:05 AM Reply With Quote
Locost option - remove the stalk and fit a rocker switch on the dash, not as convenient and you lose self-cancelling, but better than nowt!
Benzine
posted on 2/10/08 at 11:24 AM Reply With Quote
Yeah I was thinking of doing this. Would be least fiddly!
hughpinder
posted on 2/10/08 at 11:46 AM Reply With Quote
Try your local DAF dealer - mine still gets spares for my 1988 roadrunner when I want them, and mostly reasonable.
Regards
Hugh
mr henderson
posted on 2/10/08 at 03:27 PM Reply With Quote
Maybe post a pic of what's left of the indicator switch, pound to a penny it's used on other vehicles, and someone might recognise it,
John
