stuleah
posted on 3/10/08 at 06:38 PM |
help with black top zetec engine
anybody running a kit with a mondeo 2.0 black top engine if so what ecu are you using and also what wiring loom?
i have been told that the ecu i have got from the donor car wont work because the car had its own alarm system.
big_wasa
posted on 3/10/08 at 06:42 PM |
Sounds corect, that will be the Ford Pats system
If you have the key to go with the ecu then you may be able to use it
If you get an ecu from an older pre pats car then its not so hard to wire up
stevebubs
posted on 3/10/08 at 07:19 PM |
I'm running one on GSXR Throttle bodies, Vectra GSi Injectors and an Emerald
[Edited on 3/10/08 by stevebubs]
scutter
posted on 3/10/08 at 07:30 PM |
Mine's similar, GSXR bodies, ford injectors and a Megasquirt.
stuleah
posted on 3/10/08 at 09:21 PM |
thanks for the replies.
bigwasa, i have the key and full wiring loom but i spoke to premier looms and they said the best solution is to get one of their looms and use an
older ecu. do you know which ecu to look for?
stevebubs
posted on 3/10/08 at 10:15 PM |
I would suggest an early mondeo of the same engine size...
stevebubs
posted on 3/10/08 at 10:16 PM |
PS I know where an early complete 2.0 mondeo can be found for not too much cash if anyone is interested....
posted on 4/10/08 at 10:32 AM |
Last Ford stand alone ECU was found in cvh engined Orions and Escorts from the early 90's. ECU can be identified by cvh engine with carb and
current coil pack arrangement.
big_wasa
posted on 4/10/08 at 07:38 PM |
you have u2
