Author: Subject: wheel circumference
mat.price
posted on 4/10/08 at 06:22 PM Reply With Quote
wheel circumference
As the title
I have a 14" alloy wheel on my Avon with 185/60 r14 tyres on it!
I would like to put 15" alloy wheels on it but i would like to keep the some wheel circumference as i have a mechanical Speedo and dont want to put it out!
How do I get round this, tyres wise?
Paul TigerB6
posted on 4/10/08 at 06:25 PM Reply With Quote
Use a lower profile tyre to give the same rolling circumferance. Probably want a 55 profile tyre - there are a few websites that give you the info you want. Toyo springs to mind
Edit to say a quick check gives a Toyo CF1 185/60/14 as 578mm. A 195/50/15 is also the same diameter at 578mm and just happens to be a commonly available size with plenty of options for sticky rubber such as R888's
[Edited on 4/10/08 by Paul TigerB6]
smart51
posted on 4/10/08 at 06:42 PM Reply With Quote
You want to look up the rolling circumference rather than the diameter. The rolling circumference is calculated from the number of turns per mile rather than by putting a tape measure round it.
Paul TigerB6
posted on 4/10/08 at 07:04 PM Reply With Quote
here's a size calculator
Agree on the above yeah. Rolling circumference will be slightly lower due to the deflection in the tyres than the measured circumference. Still think you are perfectly safe to use the above calculator to match it up using the diameter though - the differences will be very very small once the rolling radius is worked out and well within the error allowed with the speedo i'm sure.
Still recon 195/50/15's are the way to go using the calculator.
tomblyth
posted on 4/10/08 at 07:06 PM Reply With Quote
look here there's a size calc!
[img]http://www.alloywheels.com/tyrecalc.asp[/img]
posted on 4/10/08 at 09:52 PM Reply With Quote
There's also a rolling circumference calculator (amongst other things) at the tyre bible. Just type that into google and (for once) you'll find what you're looking for!!!!
posted on 5/10/08 at 09:31 AM Reply With Quote
yep - using circumference will mean speedo will over read, whcih is what you want.
mat.price
posted on 5/10/08 at 09:45 AM Reply With Quote
ok people thanks for the info thats just what im looking for
