Author: Subject: Battery Question
r1_pete
posted on 5/10/08 at 04:41 PM Reply With Quote
Battery Question
I'm laying my electrics out and want to get as far as possible before buying the battery, I need a type 063, but when I look at it from the top as per the pic, which is the positive terminal?
Cheers.
gingerprince
posted on 5/10/08 at 04:44 PM Reply With Quote
Assuming that's the standard sierra battery, then on mine the +ve would be to the right of your diagram. My terminals are nearest the scuttle and the +ve is towards the centre of the car.
eznfrank
posted on 5/10/08 at 05:24 PM Reply With Quote
I've just bought a 063 for the Alfa tintop and it is as described above. +ve on the right.
What engine you using? I think I'd try get away with something a bit smaller, they are pretty big.
r1_pete
posted on 5/10/08 at 06:03 PM Reply With Quote
Thanks guys, its for an MGB, the 063 will fit in one of the 6v battery mounts under the back seat, was just lining up the leads, engine is a 1.8 black zetec.
