Author: Subject: Xflow Electronic Ign - Connectors?
Dick Axtell
posted on 7/10/08 at 01:49 PM Reply With Quote
Am in process of setting up my 1600 xflow with electronic ignition.
I have a Bosch, contactless xflow dizzie, which has, surprisingly enough, a Bosch connector. This is a 3-pin blade type connector. See below for pic.
Bosch_Connector_3pin
Now I've found a potential source for replacement Ford ign modules. There is one supposedly for my dizzie (Fiesta XR2 Mk 1). However, it has a Bosch 4-pin connector. See pic below.
Ford_Fiesta_ign_Module_02
So how do you couple the dizzie to this ign module? Or am I missing something?
Mr Whippy
posted on 7/10/08 at 02:52 PM Reply With Quote
[Edited on 7/10/08 by Mr Whippy]
posted on 7/10/08 at 03:06 PM Reply With Quote
Now that's what you call a concise question and answer session - have a gold star boys
http://www.locostbuilders.co.uk/viewthread.php?tid=98252
Dick Axtell
posted on 7/10/08 at 04:06 PM Reply With Quote
Thanks, Mr.Whippy. That's a very comprehensive answer.
But it still doesn't solve the main point about connecting a 3-pin, blade socket to a similar 4-pin plug.
Guess I'll have to contact Bosch, for some new terminals.
[Edited on 7/10/08 by Dick Axtell]
Mr Whippy
posted on 7/10/08 at 07:14 PM Reply With Quote
ones the tacho feed
use bullet connections instead, easy
Dick Axtell
posted on 8/10/08 at 05:11 PM Reply With Quote
3-pin to 4-pin
Nah, Mr. Whippy.
Your bottom diag shows the solution, I've now realised.
There's a connecting link between dizzie and module, which provides 3-pin socket (#6) at one end (for dizzie), and 4-pin connector (#4) at the module end.
Alles klar - many thanks for the diags.
