Steelman
posted on 23/10/08 at 07:58 AM |
Best way to remove fuel injectors from fuel rail
I need to remove a fuel injector from the fuel rail which is does not want to come out. Tried soaking overnight in WD40 with no luck, any other
suggestions
Mr Whippy
posted on 23/10/08 at 08:06 AM |
is their little metal clips?? most seem to have them. Once removed then you just tug or yank on injectors to plop the O-rings past the grove
graememk
posted on 23/10/08 at 10:14 AM |
clutch_kick
posted on 23/10/08 at 02:08 PM |
I bang them out with a 2lb hammer. It also helps unjam the injector spring inside.
scutter
posted on 23/10/08 at 02:56 PM |
And possibly snap them in the rail , remove clip and pull hard.
ATB Dan.
clutch_kick
posted on 23/10/08 at 03:35 PM |
ATB Dan.
You did realise that i was joking. Right? lol
posted on 23/10/08 at 05:52 PM |
quote: Originally posted by clutch_kickYou did realise that i was joking. Right? lol
I knew you must be joking when you mentioned a 2 pound hammer; that's barely enough to break toffee with ![](/images//smilies/bigsmile.gif)
