Chas
| posted on 28/10/08 at 09:30 PM |
SVA proof speedo
Hi guys, I need a cheap speedo to get me through the SVA test. I've heard you can use a bicycle speedo for under a tenner and wondered if I
could get any suggestions. Also, is it possible to use a wireless one to save running wires round?
Chas
austin man
| posted on 28/10/08 at 09:47 PM |
I do know that the halfords ones have been used successfully and are under 20 quid. Take the instructions with you to the SVA just in case u need to
fine tune
tomgregory2000
| posted on 28/10/08 at 09:49 PM |
i thought the display needs to be illumated to pass
tommy
robinj66
| posted on 28/10/08 at 10:10 PM |
tommy
Yep - and the power/ illumination needs to be wired up to the car battery and not rely on the internal power source. I had this checked today
clairetoo
| posted on 28/10/08 at 10:17 PM |
I dont think a wireless one will work on a car as there will too much stuff between the sender and the unit - on a bike there is just air
Its cuz I is blond , innit
Claire xx
Will weld for food......
dhutch
| posted on 28/10/08 at 10:25 PM |
I would have thought wired where better.
- Ive had wired ones working on abuot 20ft of cable (extended by soldering in additional lenght) on a boat. But the wireless ones tend to be fairly
line-of-sight.
You can get backlit ones, if thats a requiment?
Daniel
nitram38
| posted on 29/10/08 at 05:44 AM |
You also need a non-resetable odometer that is not able to be "clocked".
I think a bike one can be reset.
maartenromijn
| posted on 29/10/08 at 07:32 AM |
Hi, I am also interested in a locost speedo.
Any examples of SVA-OK bicycle speedo's?
I mean, given the above requirements it must be hard to find a bicycle speedo to match.
BLOG: http://thunderroad-super7.blogspot.com/
JAG
| posted on 29/10/08 at 10:01 AM |
My car passed SVA at Nottingham in 2005 with a wired push bike speedometer.
I used a Sigma BC1200 - mainly because it reads upto and beyond my cars theoretical top speed. I had to add a small light, wired to the cars battery,
that lit when I switched on the side/head lights.
Other than that and a little resetting during the test it passed fine. Do remember to take the instructions with you - my tester photocopied the bit
about max' speed reading. The BC1200 can read upto 183mph (300kmh) although my car runs out of puff around 120'ish.
Justin
maartenromijn
| posted on 29/10/08 at 11:19 AM |
Did you build in a small light, into the speedo housing? Or did you make a small external lamp on the dashboard?
What about the non-resetable odometer and the powersupply for the speedo itself (not speedo-light)?
| posted on 29/10/08 at 12:08 PM |
I used a cheap halfods speedo, picked up for a couple of quid at jumble sale
There is 2 white LEDs to illuminate the display, wired to car side lamps, and a little hood to prevent glare, covered with the finest quality black
insulation tape.
The magnet is fitted to a aluminium disc pressed into one of the holes in the halfshaft, core plug style. The sensor is on a bracket insdie the brake
drum.
JAG
| posted on 29/10/08 at 12:33 PM |
I built my own light that hangs over the speedo.
There was no problem with the resettable odometer or the power supply to the speedo itself.
Justin
| posted on 29/10/08 at 01:55 PM |
,,, forgot to say bout wireless speedometers. In my expereince (of 1 speedo!) and what I read about them is that the transmitter must be very close
to the the head unit, less than 1 m, if you want to work reliably.
I canmnot see how you can mount the tw=wo to be less than 1 m apart; plus there may be interference from igntion.
definitely go for a wired unit, more locost.
