Author: Subject: odd indicator circuit: 1 x 21w and 1 x 5w
stu da rude
posted on 4/11/08 at 02:56 PM Reply With Quote
Howdoo all,
One of my little projects is to get the indicator circuit up and running on my old daily, the problem is the circuit on each side has a single 21w and a 5w .
Sooo.. im thinking ill need an electronic relay, something like an RFL3 from these guys?
http://www.vehicle-wiring-products.eu/VWP-onlinestore/relays/flashers.php#elec
Would this do what i think it will? Am i right in saying these flash irrespective of load?
Mr Whippy
posted on 4/11/08 at 03:02 PM Reply With Quote
yes
stu da rude
posted on 4/11/08 at 03:23 PM Reply With Quote
So do i wire it as per a normal relay?
I.e.
Mr Whippy
posted on 4/11/08 at 03:40 PM Reply With Quote
It should be wired no different to the last one, I certainly don't see any issues, will work fine. Is there not a fuse fitted before terminal 49 to protect the relay? I would have fitted one.
[Edited on 4/11/08 by Mr Whippy]
Mr Whippy
posted on 4/11/08 at 03:50 PM Reply With Quote
stu da rude
posted on 4/11/08 at 04:02 PM Reply With Quote
Top banana..
Many thanks.
