Fan control
Snuggs - 9/5/20 at 11:14 AM
Anyone know the pin on an EEC-V (LAAN) ecu that is for the fan control relay.
big_wasa - 9/5/20 at 01:14 PM
Laan should me a mk2 Mondeo ( Blacktop ).
I think the high speed fan control will be pin 17 a black wire with a white trace ?
You will need the k46 5 pin relay for it to work for some reason. It has a diode in it between the fan out put and a separate chassis earth.
Snuggs - 9/5/20 at 01:19 PM
Cheers, I knew the oracle would have the answer.
big_wasa - 9/5/20 at 06:30 PM
It switches the earth.
You may also want to try pin 68 Black with a blue trace this is the standard fan control and may come on a few degrees sooner.
[Edited on 9/5/20 by big_wasa]
Snuggs - 10/5/20 at 07:19 PM
Marvellous, Any idea what temp it switches at ?
big_wasa - 11/5/20 at 03:30 PM
High speed was fairly high, 112degC from memory. I can't remember thr other one.
