After 3.5yrs on hold due to a garage extension, MR2 V6 build, Monte engine rebuild etc etc, I'm finally back at the point where I can re-start my
Haynes build.
This was where I started back in 2011
http://forum.ppcmag.co.uk/viewtopic.php?f=7&t=9383&hilit=roadster&sid=aa7bd3bb9cf213bc283e6e61ff4bf446
Pretty grubby after its lay up-
So a quick was down and dry off in the sun before going back into the garage-
Space cleared and floor painted. Shelves are currently overloaded with the rest of the parts for the build-
All I need now is TIME, oh and a Digidash, exhaust, pedal box etc etc
[Edited on 15/6/15 by Nickp]
Hi looking good and great to see you back on track,
If you need any body work, we can supply this, and you can get 10% off the retail with a discount code,
u2u me if you are interested,
Regards
Sean
KCD
Regards
Sean
KCD
no problem
best of luck with the build, should be a nice car with that engine in,
sean
KCD
Awesome to see you're back on it! I've since chosen to go a different way (V6) but there's anything I can help with give me a yell.
Good to see that your build is back on track. If you need any advice on the BMW lump that might stop you tearing your hair out at the same points in
the build as I did, just let me know.
After a year of having the car on the road, I can confirm that its a great engine choice. I've still not got around to doing the M50 manifold
conversion though - a job for next winter.
[Edited on 15/6/15 by SteveWallace]
Originally posted by SteveWallace
Good to see that your build is back on track. If you need any advice on the BMW lump that might stop you tearing your hair out at the same points in the build as I did, just let me know.
After a year of having the car on the road, I can confirm that its a great engine choice. I've still not got around to doing the M50 manifold conversion though - a job for next winter.
It's not particularly hard but I have to say I didn't feel it was worth the effort/cost when I had a 328 in mine.
Thought I'd trial fit the front bodywork for inspiration-
I found it more fiddly than hard and it certainly took a lot longer to do than it first appeared it would. My manifold was free of a mate so can't really comment on cost TBH. I fitted a 'remapped' ECU (ABS/EWS deleted too) at the same time and really noticed the difference when it was in the old 328i but maybe that was because the car was heavy and really needed the extra poke? I've not driven one yet but I'm guessing the 328i lump in a '7' will be pretty mental even in std form?
Yeah it is pretty quick, and an M3 will drop in when you need more :-)
With a remapped ECU the manifold might be a good option - I had a standard ECU and found the dip in torque more noticeable than the increase in power, but I think the remap should fix this. You'll definitely want an ECU that has the redline raised from the standard 6200 though.
Yeah, let me know if you figure out how to make it quiet enough to go on track :-) Mine is pretty borderline even with an 8" can. Possibly being on TBs makes it worse though?
Settled on a single welded in brace at the front of the seats to prevent any potential flexing in the middle of the floor and protect the leading edge
of my arse!!
One floor panel cut to size, just waiting for the 4mm stainless rivets to arrive-
Hello Nick! Will be watching with interest
Drivers side floor now finished and seat trial fitted into position. Feels nice and solid
Time to start on the passenger side now I'm happy the floor is nice and solid.
Thought I'd replace the sticky old bush in the steering column while I was on with sorting the seating position. Nice shiny self centering
bearing and all spins nice and freely now
Got both side floors fixed in now and both seats trial fitted. A little low at present but easily remedied with some spacers once I know the height of
the seat belt mountings on the rear rollbar-
Productive weekend in the 'man cave'.
Engine successfully lowered to clear the bodywork. Engine mounts chopped and tacked in new position. Gearbox mount totally remade.
Sump now chopped to get some ground clearance back.
Additional engine bay brace added, leaving just enough room for the alternator.
Strengthening web added to replace brace bar that was removed to allow engine to fit.
An evenings tinkering has seen the gear-change sorted.
The rear 'spike' of the original BMW gear linkage slots into a nylon / plastic bush I drilled out to size. The bush slots nicely into a
piece of tube I found which in turn was welded onto a piece of bar. Tabs were welded onto the chassis and drilled through to bolt the bar onto.
Gearstick now falls neatly to hand when seated and clears the dashboard too
Sump's now finished. Just need to measure how much capacity I've lost. I intend to fit a big oil cooler (possibly 30 row) to gain a bit of
capacity back and keep cool what I do have.
Been looking at exhaust manifold routing. The rear one clashes with the bulkhead and wants to be where the master cylinders want to be too. So
I've turned it upside down, chopped the end off and re-positioned it so the lambda sensor no longer hits the head. It should now poke out the
side of the bonnet and I can turn the front one to poke out of the side panel just below it. Hopefully it should work but I'm just tacking it
together for now until I have a final plan for the exhaust.
Sump's now finished. Just need to measure how much capacity I've lost. I intend to fit a big oil cooler (possibly 30 row) to gain a bit of capacity back and keep cool what I do have.
One thing to note, is that a lambda sensor shouldn't be pointed up like in your picture because condensation can collect and run down into the sensor causing it to fail. The build looks like it's going great
Certainly better than before, if it becomes a problem in the future you can just relocate it to another place where you can have it more upright
Hi Nick, I'm following your build with real interest! I'm embarking on a Dax Rush build using the same engine so really keen to see how you
get on. Have you had the engine running at all since it was extracted from the donor?
Regards,
Chris
Originally posted by CTLeeds
Hi Nick, I'm following your build with real interest! I'm embarking on a Dax Rush build using the same engine so really keen to see how you get on. Have you had the engine running at all since it was extracted from the donor?
Regards,
Chris
Regards,
Chris
Regards,
Chris
Sorry to hijack the thread, can you still get Dax Rush body work etc?
Regards,
Chris
No it hasn't run yet but I have a pretty simple wiring diagram that should remedy that.
I've had to remove the 2 rear frame support tubes due to the width of my fuel tank. So I'm adding these 2 extra ones which should also add a
bit of protection to the foam filled tank too.
Also added an extra tube brace across the top rail, 2 bolt on cross braces to bolt a sump guard to, welded up the new lower engine mounts and sorted
the rad mounts too
I've had to remove the 2 rear frame support tubes due to the width of my fuel tank. So I'm adding these 2 extra ones which should also add a bit of protection to the foam filled tank too.
Also added an extra tube brace across the top rail, 2 bolt on cross braces to bolt a sump guard to, welded up the new lower engine mounts and sorted the rad mounts too![]()
Ha ha, I hadn't seen yours. Great minds think alike eh?
I'm fancying the Equinox 'boot with lid', not the cheapest solution but it does look neat -
http://equinoxproducts.co.uk/store/index.php?route=product/product&product_id=63
I've emailed them for dimensions to make sure it clears everything including the tank.
[Edited on 7/9/15 by Nickp]
Ha ha, I hadn't seen yours. Great minds think alike eh?![]()
I'm fancying the Equinox 'boot with lid', not the cheapest solution but it does look neat - http://equinoxproducts.co.uk/store/index.php?route=product/product&product_id=63
I still need to do a little bit to the boot for it to fit but once in I will have approx 1.5-2cm clearance from RS11/RS12/RS6 and D12 - hope that
helps
[Edited on 7/9/15 by MBrown]
Ah cool, didn't realise you had one. How deep is it?
The boots usable space space is 24cm deep x 36cm x 56.5. It looks like a good size for a haynes
From looking at yours I don't think it will clear the filler neck, that is the reason I went with a longer tank so I could put the filler and
fuel sender at the ends to avoid the boot.
To change your tank would be a pain, or to block off and put the fuel filler towards one end would probably ruin your tank as the finish is so nice.
You could always put a 90 degree on the fuel filler so it comes out the back then amend the boot space slightly to accommodate it
Hmmm, bit of a qwandry. I could do with trying one to see if it'll be do-able before splashing the cash. Whereabouts are you based? Nowhere near
Barnsley I'll bet
Unfortunately not, I'm near Milton Keynes - i wonder if Equinox have a full diagram of dimensions so you can have a better idea
Rear roll bar made and primed-
Still deciding what to do for the rear seatbelt mounts. I'll probably put a cross piece between the bottom of the roll bar legs. Am I right in
thinking that std 25mm chassis tube won't be strong enough over such a span? I might get another piece of the 40mm box that I used for the rear
supports and weld 4 crush tubes into it.
Rear tub and one side panel roughly fitted. Wasn't keen chopping lumps and holes out of these nice new panels but I'm starting to get over
these jitters I think now
Got to say this Equinox bodywork is very sturdy and well made
Added the remaining fixed chassis panels before it all gets painted next-
Looking forward to getting some paint on it and finally get it rolling
Pedal box trial fitted-
Shiny!!
Chassis all painted now, best I start bolting stuff to it
Bit more progress
Idea is to get it rolling so I can get it under the engine hoist. Then it's engine / box in so I can measure up for prop and work out routes for
brake and fuel lines. Haven't painted the front wishbones yet as these'll be coming back off (to fit side panels) but have painted the rears
as I'm hoping these will stay on.
C/W brumming noises-
Diff's in!! That was fun on my own!! Trying to hold and balance it in place with one hand while I slipped the first bolt in.
[Edited on 9/12/15 by Nickp]
Not using the BMW diff then? Will the Sierra (?) diff take the torque?
Momentous moment, car sits on all fours for the very first time!!
Car's been up and down the drive today to turn it around
Engine in next...
[Edited on 18/12/15 by Nickp]
Before the engine goes in, I'd be interested to know what it weighs, if you have some scales handy?
Anyone local lend me some maybe?
Various sources seem to put the alloy blocked M52 around 118kg (18kg or so lighter than the iron blocked M50). The 2.0 Pinto that the car was designed
for seems to be around the 135kg mark so it would appear that I'm actually loosing some weight by adding 2 pots
The way I'm mounting the
engine should be good for weight distribution too. The rear of the head will be right back against the bulkhead with the bell housing completely in
the tunnel. 4 pots I've seen seem to have the bell housing out into the engine bay and the front of the engine in a similar position to my 6 pot.
This is only possible due to the short stumpy nature of the BMW Getrag box.
looking scary but good!
That's looking really nice
WRT choice of diff, I would have thought that the Sierra one would be up to the job. At least, I have a Sierra LSD in my Viento with the same engine
and it hasn't let go yet, and they could cope with the Sierra Cosworth lumps.
Originally posted by Rosco86
looking scary but good!![]()
That's looking really nice![]()
WRT choice of diff, I would have thought that the Sierra one would be up to the job. At least, I have a Sierra LSD in my Viento with the same engine and it hasn't let go yet, and they could cope with the Sierra Cosworth lumps.
Managed to get the nose cone and scuttle properly fixed in place for the first time, along with a few other little jobs
Before it swaps places with the Z4 again I want to get the handbrake working as its last trip down my rather steep drive was a bit dodgy, and that was
before I put the rather heavy engine in
[Edited on 22/12/15 by Nickp]
It looks like i have to cut my sump toooo
Hi Nick, what's your plan regarding the air intake? It's something I've been pondering for a while. If your using the BMW DME then you
need the MAF sensor which is a bit bulky and will fowl the bonnet I think.
Interested to know your thoughts.
Regards,
Chris
Those from shocks look a bit stiff for that flimsy chassis
Hi Nick, what's your plan regarding the air intake? It's something I've been pondering for a while. If your using the BMW DME then you need the MAF sensor which is a bit bulky and will fowl the bonnet I think.
Regards,
Chris
After many weeks of Z4 tinkering the Haynes is finally back in the 'build area'.
Prop, gear change and handbrake all connected up and working.
Looking to use this modified (bigger 2.5" inlet) Aprilia Mille can. Might fit a removeable baffle at its inlet if it's a bit fruity
Prop catcher done now too-
Hey Nick,
Is your chassis the standard Haynes "Book" dimensions?
Rob
Originally posted by Dudefladge
Hey Nick,
Rob
Thanks! It gives me hope that I'll be able to fit my Chrysler Slant 6.
Looking good Nick, nearly there!
Started mocking up the exhaust today. Pig of a job TBH, but if it was easy everyone would be doing it
Bit close to the master cylinders etc, but nothing a heat shield and some heat wrap can't sort I reckon.
Manifolds and downpipe all tacked in place. Just need a Sports Cat to go between this and the silencer.
Serious lack of updates on here on my part I'm afraid but I have been steadily beavering away and this is where the build's at now-
Next major hurdle is the wiring!! Loom's all laid out just need to start connecting stuff and apply some power!!
Exhaust is the only other big job I think
Good to see you still going at it mate, it looks very nice!
looking good, nice and tidy, where did you get that aero screen from?
Been busy working and buying / tinkering with the RX8 track toy but got into the garage for a bit tonight.
Cat' and silencer trial fitted and tacked in place-
That's looking really nice. A brief observation, but I'm sure that you have it in hand - the end of your exhaust system doesn't look
like it has a rolled edge, that would be an IVA fail. Also, watch how you position the mounting clamps for the same reason.
BTW I must make more effort to get to some track days next year, unfortunately, all of the LCB Blyton ones this year fell on days that I couldn't
make.
That's looking really nice. A brief observation, but I'm sure that you have it in hand - the end of your exhaust system doesn't look like it has a rolled edge, that would be an IVA fail. Also, watch how you position the mounting clamps for the same reason.
BTW I must make more effort to get to some track days next year, unfortunately, all of the LCB Blyton ones this year fell on days that I couldn't make.
Nice
Keep going. Book an IVA date and it will give you something to aim for.
Looks great !
Looks great !
Nice![]()
In my defence the engine / loom did
come out of the donor about 18mths ago.
Just had a pretty major panic on today. Let engine warm up a bit after last nights brief start up. As it warmed it started ticking and squealing which
then turned into a full on knock!! I had visions of having to remove the sump, which is basically an engine out job and a major PITA in such a tight
chassis. However, a mate with experience on this engine (in his E30) came to the rescue by asking if I'd removed the A/C pulley off the main
crank pulley but used the same bolts? Turned out I had and as it warmed each bolt end just clipped the timing cover and sounded horrendous. I knew it
wasn't big ends but it sounded very similar tbh. I suppose it would've eventually cleared itself as the ally cover wore away but it was much
easier to grind a couple of mm's off each bolt. PHEW!!
Sounds sweet as a nut now and has a lovely bass note to the 2.5" single silencer
[Edited on 9/12/16 by Nickp]
Hi
Just as a heads up my roadster has a simular obp brake res bracket as yours and it failed it's iva a couple of weeks ago because the examiner
said it wasn't strong enough. All I needed to do was to add a couple of support brakets at either end.
[Edited on 10/12/16 by Charlie C]
Originally posted by Charlie C
Hi
Just as a heads up my roadster has a simular obp brake res bracket as yours and it failed it's iva a couple of weeks ago because the examiner said it wasn't strong enough. All I needs to do was to a a couple of support brakets at eithe end.
Cracking on with the electrics now. Front lights all working from stalks. Engine starts on the key, which is part of the issue as I can't resist
firing it up every time I go in as it sounds soooo sweeeet!!
[IMG]http://i723.photobucket.com
/albums/ww236/enicpic/th_15531885_1729071057419571_4263993211631960064_n_zpszmalydfh.mp4[/IMG]
Just had a pretty major panic on today. Let engine warm up a bit after last nights brief start up. As it warmed it started ticking and squealing which then turned into a full on knock!! I had visions of having to remove the sump, which is basically an engine out job and a major PITA in such a tight chassis. However, a mate with experience on this engine (in his E30) came to the rescue by asking if I'd removed the A/C pulley off the main crank pulley but used the same bolts? Turned out I had and as it warmed each bolt end just clipped the timing cover and sounded horrendous. I knew it wasn't big ends but it sounded very similar tbh. I suppose it would've eventually cleared itself as the ally cover wore away but it was much easier to grind a couple of mm's off each bolt. PHEW!!
Sounds sweet as a nut now and has a lovely bass note to the 2.5" single silencer![]()
It is a nice sounding engine... have you tried firing it up without a silencer at all? It sounds brilliant, if a little loud.
FWIW I had major difficulties passing noise tests on trackdays until I fitted a second silencer under the fuel tank, this is something to consider if
you want to do trackdays.
Good info Nick. I've done exactly the same and I'm close to firing mine up as well! I guess I'll get the bolts out and shorten them a tads.
Chris
Another milestone passed as the car moved under its own steam for the very first time this evening. Only a few feet forward and back for now but still
pretty chuffed tbh
Looking great mate what make is body work?
Gary
Gary
Happy days!!! That's certainly going to be entertaining to drive..
Gary
Bought some cheap 200kg scales to weigh the car for IVA axle weights and my own curiosity.
Came in at 632.9KG 'wet'. Pretty pleased with that TBH given the size of the engine/box.
Decent balance too considering I haven't touched the spring platforms with 51/49% front/rear balance.
This is great news Nick. I've been trying to guesstimate how much my tubular chassis with the BMW lump in was going to weigh all in and this is definitely positive. Should go like sh*t of a shovel! The balance looks great too, a bit of tweaking of the suspension and hopefully you'll get the balance spot on.
Looking very smart indeed .
You must be sooo close to being IVA ready.
Originally posted by bonzoronnie
Looking very smart indeed .![]()
You must be sooo close to being IVA ready.![]()
Sending off the IVA paperwork today so thought I'd do an estimate of the build cost.
It's been built over a 5yr period, with a 3yr(ish) gap in the middle. But that meant that I've been able to collect bits at the right price
as I've gone along, used and new offers etc.
This is never going to be totally accurate but I do think it's in the ballpark and realistic.
I reckon I'll be on the road for sub £5K.
Chassis, wishbones, hubs, diff, fuel tank, column etc etc - £600
Body, seats - £450
Engine, box, ECU - £400
Pedalbox - £330
Wheels, tyres - £250
Brake parts - £200
Prop - £200
Speedo- £200
Clutch, E30 flywheel/starter - £150
Steering parts - £150
Shocks, springs - £150
Cooling, rad, fan, pipes etc - £150
Dash - £80
Belts - £50
Roll bar - £50
Bodytrim, aero, mirrors etc £150
Fuel parts - £150
Lights - £100
Loom - £50
Exhaust - £250
Nuts bolts fastenings etc - £150
Paints etc- £50
£4110 in parts to build
£450 to IVA
£? to register, tax, insure.
[Edited on 8/2/17 by Nickp]
Have you got red reflectors on the back? If you have, I can't see them!
Well, that's my good deed done for the day!
That looks realy nicely done. White is still the new black too
Nice looking car
Originally posted by nick205
Nice looking car![]()
Reflectors added, thanks for the reminder DJ
Looks brilliant Nick, well done!
Can I ask if you had any issues getting the engine going? I'm getting close to that stage(although I've been saying that for a while) and
any pointers would be really appreciated. I've already reduced the length of the bolts to avoid any interference with the timing chain case...
Thanks,
Chris
Also, in addition to the above, do you have any side repeaters for the front indicators?
Cheers [/quote
On the rear arches, just inside the permitted distance from the front of the car.
CTLeeds - 14/2/17 at 03:06 PMOh yes, nice...
Anything regards getting the engine going?
Nickp - 14/2/17 at 03:13 PMquote:
Oh yes, nice...
Not really, was a doddle tbh.
CTLeeds - 14/2/17 at 03:18 PMCool. Good luck with the IVA. Where have you applied to get it done?
Nickp - 14/2/17 at 04:04 PMquote:
Notts hopefully![]()
[Edited on 14/2/17 by Nickp]
SteveWallace - 14/2/17 at 09:58 PMquote:
That looks like a really nice build. Can't wait to see it on the track.
I only live a couple of miles from the Nottingham IVA centre, so if you need a hand or just some company on the day, let me know and I'll come along if I can. I can chuck a few bits and pieces in the back of the car in case any running modifications are needed on the day to get it through. The Nottingham testers are really helpful though and will do all they can to get if through but without compromising on the test standards.
Nickp - 15/2/17 at 04:55 AMquote:
Cheers Steve much appreciated.
jps - 15/2/17 at 03:33 PMGreat looking build - i have white Equinox bodywork too - nice to see it's going to look good!!!
I like the way you've kept the maximum of material when cutting out the side panels for the front suspension mounts etc - did you do anything to brace the GRP - especially the bet between the headlamp mount and the nosecone? I want to do the same but it all seems flimsy now i've cut out for the shock and the front upper suspension mount.
Also - did you have any trouble getting the side panels on? Mine (also Equinox) are too tight in places so i'm seeing how others have dealt with any problems.
Nickp - 15/2/17 at 04:00 PMquote:
Thanks yes white is the best colour!!![]()
I've got 4 rivnuts in the top chassis rails, one just in front and one just behind the headlamp mounts either side. Allen bolts then go through the nose cone and secure through the side panels making it all nice and secure. There's also 2 more fixings at the bottom of the nose cone back to the chassis. If you're not sure I'll get some pics for you.
My side panels were very tight too, but don't force them as I ended up with a couple of micro crack's in the gel coat. Just use a flap wheel in the grinder to take off the fibreglass matting texture top and bottom until it goes on easier.
jps - 15/2/17 at 06:04 PMquote:
Originally posted by Nickpdon't force them as I ended up with a couple of micro crack's in the gel coat.
Yep - already did that :-( I was too keen to see it in situ!!!!
Cheers for the other info - I hadn't thought of bolting through the 'cone and side panel in one - makes great sense. I am planning on using a piece of angle aluminium riveted to the bottom of the front rail to secure the bottom of the nose-cone, sounds like you've done similar but if you have got a pic it'd be great.
Cheers!
Nickp - 15/2/17 at 06:15 PMquote:
Cheers!
My bottom nose cone fixings are 2 small 90deg alloy angles. They slot between the bottom rail and the bottom front of the side panel with 2 allen bolts clamping the lot into rivnuts again, works really well and holds everything together nicely![]()
Nickp - 16/2/17 at 08:16 PMYour application for Individual Vehicle Approval has been accepted for assessment.
Vehicle Identification Number: DVLASWA...................![]()
#thisshitshappening
Nickp - 18/2/17 at 03:05 PMJust took it up the road to make sure the speedo works and the thing actually stops, all Ok there
Was quite surprised when I changed from first to second and it just smoked the rear tyres!!Oh yes, I reckon it's gonna be a beast
Think I might be needing some stickier rubber sooner rather than later![]()
[Edited on 18/2/17 by Nickp]
bonzoronnie - 18/2/17 at 03:36 PMGuess with that engine you'll be able to light up the rear in most gears.
Great to read that the IVA process is well under way, no doubt you will have a test date in the very near future.
Nickp - 18/2/17 at 04:16 PMquote:
Guess with that engine you'll be able to light up the rear in most gears.![]()
Great to read that the IVA process is well under way, no doubt you will have a test date in the very near future.![]()
Yeah it's going to take a steady right foot to start with!!
I'm expecting/hoping the test centre to get in touch this next week. I said the car would be available from the 24th.
Nickp - 19/2/17 at 07:08 AMLeaving the car ticking over on the drive yesterday made me realise how vital some bonnet vents are. With the bonnet off it sat happily at about 80 to 85deg with the fan cutting in and out. When I put the bonnet on it crept up to 95deg and the fan was running permanently. I'm using the bigger 1.6 VW Polo rad but only time will tell if this is going to be up to the job.
CTLeeds - 19/2/17 at 09:43 AMI'd wondered if you were going to cut a hole in the bonnet scoop? The Rush I'm building has this scoop and also has flared wings which will hopefully get rid of some of the heat when stationary.
Good to hear it's a bit of a handful!
Chris
Nickp - 19/2/17 at 09:57 AMquote:
Chris
I've cut a hole in the front of the scoop now to let air in when moving but it needs some bigger vents to the rear of the bonnet to let the hot air out.
PGD - 20/2/17 at 04:59 PMSuperb build, well done! Would be good to see it sometime, I'm pretty local in Ossett, Wakefield..
Nickp - 20/2/17 at 05:36 PMquote:
Cheers fella, I'm quite pleased for a first attempt![]()
You're welcome to come take a look or can meet up sometime once I'm roadworthy.
gary gsx - 20/2/17 at 09:51 PMI'll second that that's a superb looking build and I bet it's going to be stupidly quick.
Great stuff
Garf
dmrider_10 - 22/2/17 at 12:59 PMFantastic looking build! Very surprised at the cost being 5k, that actually has me thiinking! Was the chassis bought off here/ebay etc?
Ben_Copeland - 22/2/17 at 02:12 PMStill struggle to get air into mine !
Nickp - 22/2/17 at 07:17 PMquote:
Off a mate actually who realised he'd never get it done. Came with loadsa good bits too![]()
Nickp - 22/2/17 at 07:19 PMquote:
You've got turbo heat though Ben. Hopefully mine won't be so bad, I've got the manifolds wrapped too. Deffo need to get the hot air out once it's passed the IVA![]()
Ben_Copeland - 22/2/17 at 07:25 PMYeah and the turbos soon to double in physical size
Nickp - 22/2/17 at 07:37 PMquote:
Yeah and the turbos soon to double in physical size![]()
That'll help![]()
Nickp - 23/2/17 at 09:21 PMIVA test date booked Fri 10th March at Nottingham, fingers crossed
Ben_Copeland - 24/2/17 at 04:49 AMGood luck !!!
gary gsx - 24/2/17 at 08:26 AMGood luck mate
Gary
bonzoronnie - 24/2/17 at 08:53 AMAll the best for the big day Nick.
A Splendid looking build, a real credit to all of your hard work.
Nickp - 2/3/17 at 02:31 PMquote:
All the best for the big day Nick.![]()
Cheers fella![]()
Just been getting insurance quotes as my current insurers said they wouldn't offer any cover until I had a reg number. I explained that I could legally drive the car to the IVA, but they wouldn't cover it. I'm not driving it there but they didn't seem to know the score at all tbh. Currently my best quote is £145 fully comp with an additional £45 for full uk/Euro breakdown, happy with that TBH![]()
craigdiver - 14/4/17 at 09:19 PMNick, who did you use for the ABS/EWS delete?
Craig
Nickp - 18/4/17 at 09:13 PMquote:
Craig
Can't remember exactly TBH, it was a long time ago. It was just off ebay. Sent him my ECU and it came back sorted, both deleted, 7krpm limiter and a remap to suit the M50 manifold![]()
CTLeeds - 19/4/17 at 10:52 AMquote:
Craig
I used END Tuning in Birmingham to do mine. Really good service and quick turnaround.
http://www.endtuning.com/
Chris
craigdiver - 22/4/17 at 06:47 PMThanks guys for the info on the ECU reprogram.
Nick/Chris, what lbs of springs did you end up using front/back and are you happy with them?
[Edited on 22/4/17 by craigdiver]
Nickp - 22/4/17 at 06:54 PMquote:
I'd have to check but 400fr 250rr rings a bell. Too early to say if they're spot on but initial impressions are good.
craigdiver - 23/4/17 at 04:47 PM
Hello, all photo on your thread are unavailable
Originally posted by scoommy
Hello, all photo on your thread are unavailable![]()
No problem Nickp, i Know it's not your fault. Do you have a blog or other link to see your seven ?
Hi Scoommy, if you use Chrome browser, the
"Photobucket embed fix"
extension will sort the photo problem out for you
Originally posted by UncleFista
Hi Scoommy, if you use Chrome browser, the "Photobucket embed fix" extension will sort the photo problem out for you![]()
Thanks that work great !!!![]()
@Nickp : Your build is realy brilliant ! i hope mine will be so beautiful![]()
Hi Nick, did you get anywhere with your corner weighting?
Regards,
Chris
Yes M52B28, i take it in 528i
My project just start i give you some news when i advance.
Do you think it's possible to use BMW parts for drive train ?
I live in Saint-Malo
Yes M52B28, i take it in 528iMy project just start i give you some news when i advance.
I live in Saint-Malo![]()
Scoomy, I'm using the same engine from a 328i. If you need any advice just ask.
Chris
Thank you so much Nickp & CTLeeds
Hello ! I have 2 or 3 small questions ;-)
- Do you have heat problems with this "big" engine in your seven?
- How do you get speed information? Via the ABS sensor?
Thank you for your help.
Nico!
[Edited on 14/4/18 by scoommy]
