Hi all, this is a continuation of my chassis build thread which can be found
-here-
So I have now completed the chassis. I will be using equinox bodywork and have now painted the chassis and riveted on the aluminium floor and gearbox
tunnel panels.
I know I am using the same engine as a few people at the moment but you can never have too many build threads
More the merrier I say
I like this engine so much that I've gone out today and bought another one to keep me amused until mine's finished
[Edited on 7/10/15 by Nickp]
I can't wait to hear it, hopefully won't be too long until I get it started! I'm watching your build too and it's definitely giving me some ideas!
I'm mega excited to see my old engine running again
Originally posted by blakep82
I'm mega excited to see my old engine running again![]()
Ha ha I said the same thing! Done by the spring. Spring 2007 originally...
Today I built a simple rivnut tool, which is just an alteration to the nut and bolt idea. Tool explanation here:
Rivnut tool
[Edited on 10/10/15 by MBrown]
Rivnuts added into the bottom of the chassis in pairs to bolt on some aluminium angle when/if required as jacking points.
[Edited on 11/10/15 by MBrown]
So engine is back in. It is such a close fit everywhere, I'm glad I've got it in and I'm sure it will be worth it but consider
carefully before choosing this engine route!
Also for those who have gone this route, don't forget to either put gearbox oil in before the engine goes in, or have a small removable access
panel in the drivers footwell!
Progress continues! - Finally! Moving house has prompted progress to get it onto wheels. Pics hopefully tell the story of the last couple of weeks.
I had a problem with my front hubs (seized and snapped bolt which I couldn't remove or drill and neither could my local trusted garage) so I went
for some refurbished ones.
Work to do still seems endless, next jobs - I want to finish the roll bar then I'll finish fitting the pedal box and run the brake lines, fuel
lines etc. So far:
13
14
pg]122038[/pg]
11
3
2
5
6
7
[Edited on 6/9/19 by MBrown]
