Hi All,
Just getting all the parts to build up the rear hubs.
From what I have read, the front plate has the holes horizantal for drum, vertical for disc? Or have you guys done something different?
Cheers!
Hi
My rear disc hubs are at 45degress pointing to the rear and upwards.
Charlie
Cheers, so say at 2 o'clock position?
hi
Have a look and this Haynes Forum post
I purchased mine ready built so I'm not sure of the exact rotation, the advice on the Haynes post is to mock it up with the calliper and remember
to make sure the handbrake cable have clearance.
Hi Guys,
What do you think?
Roated to 45 degrees, tem handbrake cable doesnt fowl anything etc.
[img][/img]
[img][/img]
Hi guys,
What do you think before I start fully welding the hubs?
Many thanks.
