Mx5 based kit wishbones
mikeey_boy - 6/6/18 at 07:02 AM
Hi all, I have a question regarding the Saturn plans for modifying the chassis to take mx5 running gear.
With regards to the wishbones - are the mount points to the haynes chassis in the same position as they were on the mx5 subframes?
Slimy38 - 6/6/18 at 06:05 PM
If you're thinking of reusing the MX5 wishbones then unfortunately they won't fit. They're set up similar to the original 'build your car on a budget'.
mikeey_boy - 6/6/18 at 06:27 PM
Thanks for the reply, I had suspected as much!
