Is there any modification needing done to the Chris Gibbs Haynes Roadster book-spec wishbones if using the Cortina uprights to ensure correct caster, self-centring etc?
A quick Google search directed to the two threads below
http://www.locostbuilders.co.uk/viewthread.php?tid=141750
http://forums.haynes.co.uk/showthread.php?t=2487&highlight=cortina+uprights
Your right there is no definite answer, I would like to convert over to cortina uprights and have better castor angle than the sierra set up.
I did consider swap to an MX5 upright as there are plans for the wishbones and changing the front wheel due to the PCD is different.
No that won’t work, the Sierra tops are shorter. So the mounting points will be in free air.
Your making hard work of this.
Make a jig as per book but make Bottom and top 2” longer to match the +4” rear axle.
The top wishbone transit drag link bush wants offsetting between 22 and 25mm instead of the 11mm in the book.
Make the bottom plates around 5mm and make them curved with no sharp edges. Use a good seamless tube or go up a size for ERW like 2mm.
It works....tried and tested....it will pass Iva.....
Dave’s vid
[Edited on 14/1/19 by big_wasa]
Dave’s vid
I don't have the book to hand to check dimensions but I would try and get the tubes as central on the bush sleeves as you can.
It doesn't make any odds what bushes you use as long as the width adds up.
