Hi Guys,
Can anyone recommend a free 2D cad software, so I can design a wiring diagram.
Terry
Draught Sight, very good. I use the professional version.
link
Yep as good as autocad.
A seconder for draftsight
I'm interested in this too. Used to use AutoCAD 2D and Solid Edge 3D at work, but having move to the sales side of the business I no longer use
either. I'd like to be able to produce some dimensioned drawings of simple components. Mainly for having things made.
To those that recommend Draftsight can you post up any example drawings you've done?
I use Tekla mostly due to working in the steelwork industry, however we use draftsight alot.
Its not really any different to Autocad.
We typically export drawings into .dwg format for use in draftsight etc.
ZWCAD is another good alternative
I do prefer draftsight though
Installed Draftsight, but then it returns an "error" when I try to register and refuses to open.
Not much cop for me I'm afraid
you have installed the wrong version
there are 32 bit and 64 bit versions it will not run if you have the wrong version.
its as good as autocad. I use both on a daily professional basis there is very little difference between the 2
when up and running use the classic interface I find it better but then i'm an old git and used autocad for some 15 years or so
Well the 32 bit version won't even install - stops and says "you have a 64 bit OS, please download and install the 64 bit version".
Out of patience now.
What a PITA
1. Re-installed the 64 bit version
2. Received the "activation" email, clicked the link and got a "success" webpage
3. Tried to open Draftsight.....nothing
A bit of a joke really
[Edited on 23/5/17 by nick205]
I must admit, I was very sceptical when I first downloaded draftsight. I remember thinking that I've used AutoCAD for years, so how can free
software be anywhere near as good?!?! surely it will be limited etc.....
Well the truth of the situation was that apart from a couple of minor differences, generally speaking draftsight and autoCAD are identical.
Very impressed, especially given draftsight is free
I installed Draught Sight , but i keep getting an error message when I try to activate it through there website.
Looks like i'm going to do it the old way, pass me the pen and paper
Terry
[Edited on 23/5/17 by TKPM]
Don get it. U can run for 30 days without a licence. I have just created a sand box and installed no problem. Confused of bolton
Ps don't think it will run on xp !
I've just tried again to activate it again and it now works. Now just have to work out how to use it lol
Terry
Easy peasey lemon difficult.
But there again I do use cad for a living.
P's plenty of help on youtub
Thanks for the tip Bart
Terry
Early Draftsight responded to the Autocad keyboard shortcuts, so was Autocad in all but name.
The later versions don't respond to the same shortcuts that the early did. Been using Acad since '93, version 10. Draftsight is about the
best software for purpose that you can get.
Nev.
Fiddling got the better of me so I tried again with the 64 bit version.
Activation email worked this time and now the software runs OK.
Might have some time over the weekend to play with it.
Used to be an everyday user of AutoCAD, but not for a good few years so there'll no doubt be some learning to do.
As I say use classic interface
top left hand pull down box , 2 options ribbon or classic
Resurrecting an old thread!
First, I don't appear to have a pull down box as mentioned in the above post, are there several different versions of Draftsight or am I just
being thick!?
Secondly, I have loads of old drawings I did using a different drawing programme which has now failed & is no longer available (it didn't
work with Windows 10 anyway so was already giving me problems), all the old drawing files are saved as .dwg as my laser cutting firm want, however, if
I open one of the old drawings in DS although you can view it & it all looks fine, if I try to edit it then the grid doesn't automatically
match the drawing, if I change grid spacing to 0.25 it then appears to match points on the grid to points on the drawing, but if you turn
"snap" on then it goes barmy & snaps all over the place to bizarre points! I can overcome it by turning "snap" off & going
manually to a point to draw from, but I'm worried that if I then edit & save, what the laser cutters are going to see isn't what I
intended as measurements from the original drawing don't appear to match dimensions on the new drawing (sorry, this is really hard to explain!) -
I'm guessing something is bastardised in the swap between drawing progs?
So, therefore I think anything I need to edit I am going to have to redraw from scratch, with that in mind, is anyone aware of any long term
restrictions using the Free version of DS. ie am I going to need to buy the product at some point & what are the long term costs if that's
the case?
I will u2u you
Bart, many thanks for your assistance!
