Hi guys.
For those of you running a zetec, just wondered where you sourced your exhaust system from?
Is it more likely to get one fabricated as finding a suitable exhaust manifold looks pretty bleak...
Regards,
andy
maybe the Westfield kit will suit you?
http://www.westfield-sportscars.co.uk/shop/prodtype.asp?PT_ID=77&numRecordPosition=6&ph=cat&strKeywords=&&strSearchCriteria=
christ! it would suit me if i was a rich bugger! i was looking for something a little more locost... i'll see if they do a manifold on its own though...
oh they do, still 300 nicker for it though.....
I'm cutting and shutting an ST170 maniflold -- it's 400 series stainless, so it'll still rust a bit but I think it'll look ok with
a bit of VHT on it. I had a free one kicking around but they should be reasonable from a breaker.
Cheers, Ted
What about the vindicator ones on eblag, hang on I'll get you a link....
LOCOST VINDICATOR SEVEN ZETEC 421 EXHAUST MANIFOLD KIT on eBay (end time 23-Jan-11 13:25:36 GMT)
LOCOST VINDICATOR SEVEN ZETEC 4-1 EXHAUST MANIFOLD KIT on eBay (end time 31-Dec-10 18:15:43 GMT)
Rich
I got mine from GBS.
Very pleased with it.
B
GBS Have great service, i would highly recommend
GBS Link
don't suppose you guys have got any photos of the actual gbs manifold and maybe some dimensions?
I got mine from a company called tube engineering near peterborough - they used to supply the old luego when they were based in peterborough.
Quality is very good and the whole system was reasonably priced.
Might be worth a phone call, they even polished the whole system for an extra tenner !
I got mine from fisher sports cars.
I made my own due to lack of room on that side. Sounds great and not too expensive. Good luck.
I had mine done at Powerspeed in Ashford Kent.
Great job as I wanted it inside the engine bay and I also wanted it free flowing to get the best out of the engine.
I'm pleased.
HTH's
.........Neil
